Are the drive shafts the same for both uni and pot joints?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14418
Author:  Bromley [ Fri Dec 30, 2005 3:16 pm ]
Post subject:  Are the drive shafts the same for both uni and pot joints?
Got some new CV's and wondering if the drive shafts I have formerly used with uni joints will accomodate a pot joint.
Thank you.
Author:  9YaTaH [ Fri Dec 30, 2005 3:21 pm ]
Post subject:  different
Andy .....pot joints need the correct output shfts...another problem for you.....Happy New Year :D
Author:  Bromley [ Fri Dec 30, 2005 3:23 pm ]
So they have a different type of spline on the end? Wish I had one of each to compare (trip to Tims???)
By the way, hanks for that link Mick but I think second hand is cheaper. Might post on here for a few actually.
Author:  9YaTaH [ Fri Dec 30, 2005 3:29 pm ]
Post subject:  just another photo....
Yeah...go see Tim and ask to see a pot-jointed gearbox.....there is a thread or two here explaining what you have to do....not easy...but worth it.
The link was to show you that any fool with a hacksaw and file could make those door spacers ....as I suggested :!: :shock:
(Caveat: any inference that Brom is any fool is unintentional and regretted :D )
Author:  drmini in aust [ Fri Dec 30, 2005 3:36 pm ]
Pot joint shafts are both longer, and have a different spline (and a circlip groove) at inner end than the others. :wink:
Author:  Bromley [ Fri Dec 30, 2005 3:54 pm ]
So I have disk brake CV's (for the disk brakes) and drive shafts.
I have discovered that the later style pot joint g/box is better and easier to find
Therefore I need to find pot joint style drive shafts for the cv joints instead of using the ones that came with the brakes?
[/quote]
Author:  drmini in aust [ Fri Dec 30, 2005 3:59 pm ]
yes. The shafts just pop out of CV after you smack them smartly with a BFH.. :wink:
