IwannaMini wrote:
OK... questions about building a basher... wanted for Motorkhana and Khanacross but nothing too competitive...
1. Would you use Hydro or should it be dry (longevity & ability to soak up bumps)
2. Whats the rules and regs about roll cages
3. How many seats are required.
4. Does it ultimately have to be registered or is "roadworthy" OK.
1. what have you got? use it.
2. if you wanted to put a roll cage in, do it properly and get a CAMS/FIA approved one. but it is not necessary for motorkhana or khanacross as they are not considered speed events by CAMS, and if a car is not logged by CAMS, it does not need a rollcage for speed events like hillclimb or supersprint. for your immediate needs for motorkhana basher, don't worry about it
3. one for you to drive from. my car only has one seat, a race seat donated by my brother but fitted properly with the right reinforcing plates etc. but you must have a functioning seatbelt that will pass scrutineering. for motorkhanas you can get away with just the lap belt, which is what i do with the full harness in mine, i just tie the shoulder straps up so they don't hit me in the head. for a khanacross you need at least a functional lap/sash belt.
4. it has to pass scrutineering, which means they look for the obvious - nothing loose that could break free and hit you. no major structural rust, wheels that won't fall off, brakes work. safe to say that if you could get a pink slip it will be ok, if not it won't be. remember its your safety, and CAMS actually lays all the responsibility on you as the entrant to ensure the car is safe.
come on Marcello, with the number of cars you have, there must be one you could quickly turn into a basher.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
