Clutch Adjustments https://www.ausmini.com/forums/viewtopic.php?f=2&t=14492 |
Author: | mccabe998 [ Mon Jan 02, 2006 1:06 pm ] |
Post subject: | Clutch Adjustments |
hey guys i own a 72 clubman, i am adjusting the clutch to try and get the thing into gear, i have adjusted it to specs in book using a feeler gauge and it had made the clutch really awkward to push in this doesnt seem normal, all fluid levels are right!! hydrolics are working! |
Author: | 9YaTaH [ Mon Jan 02, 2006 2:11 pm ] |
Post subject: | Re: Clutch Adjustments |
mccabe998 wrote: i have adjusted it to specs in book using a feeler gauge and it had made the clutch really awkward to push in
Ahhhhh McCabe, you've done it again ![]() What you mean by awkward ![]() ![]() ![]() ![]() Do you have a spring across the slave cylinder on top of the clutch housing ![]() Is the clutch operating now ![]() ![]() |
Author: | simon k [ Mon Jan 02, 2006 2:24 pm ] |
maybe by awkward you mean that it's hard when you first push the pedal, then kinda gets easy all of a sudden as you get close to the floor - take some adjustment out if that's the case, cos you don't want it going in too far... but it's not a big deal. it'll always feel wierd after adjusting, because you get used to it a particular way and then it changes all of a sudden, particularly if it was a long way out before you adjusted it |
Author: | mccabe998 [ Mon Jan 02, 2006 2:39 pm ] |
almost got it!!! i reckon it will go in soon!!! if not im gonna get a mechanic to do it for me! |
