most automotive bog is actually polyester resin with talc. and most cheap fibreglass repair kits are also polyester resin.
but yeah - bog is a filler for smoothing SMALL dents and other imperfections. to avoid the rust issue that polyester resin fillers may present, you can use "marine" filler which is designed to be used in a wet environment and so uses vinylester resin i think, less water penetrates. any repair of a hole using filler is dodgey because it has no strength at all, and is usually done by people who want to paint oer it and sell the car on. they don't care if it falls apart in a couple of weeks time.
what most people refer to as fibreglass is resin reinforced with glass fibres in the form of chopped strands. it is very good stuff, but most repairs done using it are not done properly. you still have to get rid of ALL the rusty metal and have a perfectly clean rust free surface to bond it to. you may as well do the same prep for a welded steel repair - if you know how to weld. also you can't sand the cured article because the fibres come through the surface, so for a perfect smooth finish you still need to use filler over the top and sand that.
you can also get the glass fibres in the form of woven cloth, continuous random orientation fibre mat. there are also many other fibre/resin combinations like epoxy with carbon fibre or aramid fibre (kevlar is the dupont brand).
for really good, easy to work with fillers you can use epoxy resin mixed with glass microspheres or West Systems has something called microfibres(i think, brown stuff really light), which are all heaps easier to sand than talc in polyester. West Systems sells that stuff for boats, but they still need a paint over top to make it waterproof.
check out
Fibreglass Material Services (FMS)
http://www.fibreglassmaterials.com.au/, seven hills, gosford, newcastle
Fibreglass International (fgi)
http://www.fgi.com.au/ brookvale nsw , cairns, labrador, wacol qld, green fields SA, springvale vic, canning vale WA
or SP Systems
http://www.spsystems.com at Mona Vale for good advice and materials for anything in composites
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
