new engine mounts..good/bad?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14545
Author:  64mini [ Tue Jan 03, 2006 7:08 pm ]
Post subject:  new engine mounts..good/bad?
Just fitted new RH engine mount and now when i stop anywhere the engine vibration drums through the car. In saying this the mount will it loosen up?
Should I now replace the LH? Will it be worse?
Anyone have the same problem?
I am running a mod RE-13 cam which is nice and lumpy, so any help be good.
Author:  drmini in aust [ Tue Jan 03, 2006 7:13 pm ]
what speed is idle? Mine idles nice at 1200, with either the RE13 or RE282 cam...:)
Author:  64mini [ Tue Jan 03, 2006 7:15 pm ]
idle is 1000
Author:  64mini [ Tue Jan 03, 2006 7:16 pm ]
You don't find that 1200 is to quick?
Author:  drmini in aust [ Tue Jan 03, 2006 7:17 pm ]
No, it's fine.
With the 282 cam in it now, I need to rev it more for takeoff anyhow.. :P
Author:  64mini [ Tue Jan 03, 2006 7:23 pm ]
Does the 1200 take the lump out of the engine?
Are the new mounts a harder compound?
I found when putting the engine in that two new mounts would not fit, so i have now done one side while the engine in, will the other side go in or have I got two hopes of lineing it up?
I been told only one new mount will go in and should leave your best old mount in?
Author:  drmini in aust [ Tue Jan 03, 2006 7:26 pm ]
Are these mounts the ones with the `captive nuts' in? If so, they are too bloody thick..:(
Yes only use 1, if so.
Yeah unless you got a crowbar and block of wood, bloody hard to fit 2 in.
Author:  gafmo [ Tue Jan 03, 2006 7:27 pm ]
I Hear you..did you fit the new one's with the nuts welded on..Jam was getting two of these and we could not fit both on..So we also fitted one of the new one's and the best of the old also :wink:
Author:  64mini [ Tue Jan 03, 2006 7:28 pm ]
no nut welded, just std mounts
Author:  9YaTaH [ Tue Jan 03, 2006 10:23 pm ]
Post subject:  Re: new engine mounts..good/bad?
I think its the cam...to lumpy mate...I'll take it off your hands :wink:
I've heard that new engine mounts aren't being made as good as the originals....
but maybe you should replace the other side as well because now you have stiffened up one side the ...tuther may be flopping around..
How are your engine steady bushes :?: :?:
Author:  drmini in aust [ Wed Jan 04, 2006 5:57 am ]
Yeah, I had Lurethane steady bushes in mine (with remote box) a while back and it vibrated, so I went back to factory rubber ones. :D
Author:  64mini [ Wed Jan 04, 2006 2:16 pm ]
ok! I took the new mount out and put the old mount back in and guess what....
No vibration!!!
Ok so now I am getting a good old mount to replace the stuffed one.
I not think much of the new mounts a bit to firm for me.
Runs a lot smoother with the original mounts.
Author:  Lillee [ Wed Jan 04, 2006 2:20 pm ]
I run on 1100rpm idle, anything lower is too lumpy and I aint even running an RE13! :P
Author:  64mini [ Wed Jan 04, 2006 2:31 pm ]
i got my idle back to 900 with old mount back in, I love the sound of the lumpy idle :D
