ohm range of your fuel gauge? https://www.ausmini.com/forums/viewtopic.php?f=2&t=14581 |
Author: | jacks1071 [ Wed Jan 04, 2006 4:44 pm ] |
Post subject: | ohm range of your fuel gauge? |
Hi to all, This is going to be an odd question. I'm looking into fitting a fuel cell to my mini and one of the fuel cell dealers has asked what the ohm range of the fuel gauge is. Anyone know the answer to this? I want to use the fuel gauge that is integrated with the speedo, got enough gauges so really don't want a seperate fuel one. If you havn't looked at these checkout: http://www.racerpartswholesale.com/fsafe1.htm or http://www.atlinc.com/ They are a very interesting product. Thanks, Jacks. |
Author: | ken@miniauto [ Wed Jan 04, 2006 5:46 pm ] |
There are two types of sender The early one is bolted in. The gauge has no voltage stabiliser fitted The readings for this are Empty 0 ohm 1/2 45 ohm Full 72 ohm The later type is held in with a lock ring and the gauge is fitted with a voltage stabiliser Empty 240 ohm 1/2 65.5 ohm Full 19 ohm |
Author: | jacks1071 [ Wed Jan 04, 2006 9:34 pm ] |
Post subject: | Re: ohm range of your fuel gauge? |
ken@miniauto wrote: There are two types of sender
The early one is bolted in. The gauge has no voltage stabiliser fitted The readings for this are Empty 0 ohm 1/2 45 ohm Full 72 ohm The later type is held in with a lock ring and the gauge is fitted with a voltage stabiliser Empty 240 ohm 1/2 65.5 ohm Full 19 ohm My car is a 1965 model - easy way to tell which it is? Thanks J. |
Author: | ken@miniauto [ Thu Jan 05, 2006 8:02 am ] |
Check the rear of the speedo unit The early type has the fuel guage sticking out of the assembly The later type has the fuel guage inside the housing and you should be able to see the voltage stabiliser attached to the speedo housing. The power to the guage comes from the stabiliser |
Author: | jacks1071 [ Thu Jan 05, 2006 10:14 am ] |
ken@miniauto wrote: Check the rear of the speedo unit
The early type has the fuel guage sticking out of the assembly The later type has the fuel guage inside the housing and you should be able to see the voltage stabiliser attached to the speedo housing. The power to the guage comes from the stabiliser I'm using a brand new speedo from Mini Sport - its got 130mph and 200kmph on it. Will that be the same? |
Author: | IanD [ Thu Jan 05, 2006 11:10 am ] |
There are two types of sender The early one is bolted in. The gauge has no voltage stabiliser fitted The readings for this are Empty 0 ohm 1/2 45 ohm Full 72 ohm The later type is held in with a lock ring and the gauge is fitted with a voltage stabiliser Empty 240 ohm 1/2 65.5 ohm Full 19 ohm My car is a 1965 model - easy way to tell which it is? Uuumm J, which part of bolt in or lock ring (see above) don't you undersatnd? If you're talking about the gauge; an early gauge (bolt in sender) will immediatley flick to the reading when you turn the ignition key. The newer gauge sort of creeps up to the reading (and, as stated, has a voltage regulator (small metal cannister about 1 cm by 5 or 6) attached to the back of the speedo (somewhere). Cheers, Ian |
Author: | ken@miniauto [ Thu Jan 05, 2006 7:03 pm ] |
Your fuel gauge suits the later type sender Empty 240 ohm 1/2 65.5 ohm Full 19 ohm You will need a voltage stabiliser if not already fitted to the speedo |
Author: | 9YaTaH [ Thu Jan 05, 2006 7:10 pm ] |
Post subject: | Welcome |
IanD wrote: There are two types of sender
The early one is bolted in. The gauge has no voltage stabiliser fitted The readings for this are Empty 0 ohm 1/2 45 ohm Full 72 ohm The later type is held in with a lock ring and the gauge is fitted with a voltage stabiliser Empty 240 ohm 1/2 65.5 ohm Full 19 ohm My car is a 1965 model - easy way to tell which it is? Uuumm J, which part of bolt in or lock ring (see above) don't you undersatnd? If you're talking about the gauge; an early gauge (bolt in sender) will immediatley flick to the reading when you turn the ignition key. The newer gauge sort of creeps up to the reading (and, as stated, has a voltage regulator (small metal cannister about 1 cm by 5 or 6) attached to the back of the speedo (somewhere). Cheers, Ian Welcome stranger ![]() ![]() |
Author: | jacks1071 [ Sat Jan 07, 2006 12:54 am ] |
ken@miniauto wrote: Your fuel gauge suits the later type sender
Empty 240 ohm 1/2 65.5 ohm Full 19 ohm You will need a voltage stabiliser if not already fitted to the speedo Thanks Ken, does the new speedo normally come with the stabiliser or is that a seperate unit? Thanks, Jacks. |
