engine steadys
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14612
Author:  benjamin [ Thu Jan 05, 2006 11:18 am ]
Post subject:  engine steadys
i have a remote gearbox but i have a left and right engine steady, beacues my car used to be a rod box.
now my question is can i take the stead under the thermostat out?, if its nots supposed to be there on remote boxes i suppoze it doesnt matter but i just want to be sure.
Author:  sports850 [ Thu Jan 05, 2006 11:22 am ]
Depends , doesn't hurt to hold things steady , I snapped an engine steady on an earlier mini at the traffic lights , don't know how it did but it's not a good feeling when your motor starts bouncing backwards and forwards in the engine bay ..... What size motor have you got ?
Author:  GT1360 [ Thu Jan 05, 2006 11:23 am ]
it will not kill it... my 1275 remote does not have a right side steedy... and if you look at all the turbo minis I think the dont have em also due to the bulk head been cut out :wink:
Author:  Benny_boy [ Thu Jan 05, 2006 8:44 pm ]
I totally disagree, i have a 1275 an i was getting a fair bit of movement in my engine, however silly me didnt thing much of it. but then i went for a boot out king lake direction iI ran into a spot of bother. With all the engine movement I was getting, my 3 into 1 extractors blew completely apart where the 3 pipes join into 1. this happend 2 hours from home :(. I then put a left hand steady on it and the engines like a rock. If you have taken it off, i suggest you put it back on :)
Author:  drmini in aust [ Thu Jan 05, 2006 9:34 pm ]
I run a big HP 1360 on a remote box, with only the original standard steady. Never felt the need for the rodchange one, all it does IMO is make it hard to work on things.
Cooper S neither had it nor needed it. :wink:
Remote box has a `torque arm' anchored in the tunnel, nearly 1M long, so has no need for another top steady.
Author:  GT1360 [ Fri Jan 06, 2006 5:28 am ]
get a remote box :lol: The Ultimate Engine Steady
Author:  Matt 848 [ Fri Jan 06, 2006 8:06 am ]
The 1275 Californian I use to have (slightly hot) had a habit of snapping the mounting bracket not the steady. After the third time I had one welded up specially and it didn't break again. It started to snap drive shaft/axles after that ??????
