Brake Question - Master Cylinder?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14620
Author:  Flashback [ Thu Jan 05, 2006 3:26 pm ]
Post subject:  Brake Question - Master Cylinder?
Just took the Traveller out of the garage for a quick drive this arvo, however when I pushed the brake pedal gently it went straight to the floor! when I then pressed it quickly it hadfull pressure. I've tried it several times and it will do it repeatedly.
There are no obvious leaks or loss of fluid so I can only think it's a master cylinder problem.
Any ideas guys before I rip it out?
Author:  simon k [ Thu Jan 05, 2006 3:35 pm ]
probably not the master cylinder, cos it wouldn't hold any pressure, more likely some air has gotten into the system, or a brake line has turned into a balloon
Author:  Steve [ Thu Jan 05, 2006 3:36 pm ]
Clamp off all brake lines and put your foot on the peddle, if it slowly sinks its the master if not start checking the wheel cylinders
steve
Author:  Flashback [ Thu Jan 05, 2006 3:42 pm ]
Cheers guys, I'll have a look in the morning.
Author:  TheMiniMan [ Thu Jan 05, 2006 6:13 pm ]
Master cyls can do what he`s saying & when they do that , then it`s normally cause it`s internally by-passing, that is fluid will pass through the worn primary cup when pedal is gently pressed, but shove it hard & the cup expands greatly under the high pressure & seals (for now) :-)
easy-peasy
Author:  WhoDat [ Thu Jan 05, 2006 6:16 pm ]
Has it been recently re-kitted???
I have seen this one - there are 2 sizes of master cylinder 0.70" and 0.75"
If a large bore master cylinder AND it is litted with the wrong [smaller] punger rubber, then on gentle pressure the fluid just leaks around the plunger rubber [still within the cylinder bore] and the pedal goes to the floor. But if you stab the peda hardl, the sudden pressure forces the cup out against the bore sides and pressure is maintained [while you have your foot on]
FWIW
Dat
