Duel circuit master cylinder
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14653
Author:  72clubman [ Fri Jan 06, 2006 2:26 pm ]
Post subject:  Duel circuit master cylinder
Is there any disadvantage over having a mini with a Duel circuit master cylinder over the single circuit, cause i have a brand new single circuit cylinder, but the tandem one works fine aswell although its is getting old, i am putting cooper s disc brakes and also wanted to know if the duel circuit cylinder will work ok.
also what is needed to convert from duel to single apart from the master cylinder
Author:  Mike_Byron [ Fri Jan 06, 2006 3:56 pm ]
Dual circuit were fitted because of ADR design rules and the fact that itstill gave you brakes should a circuitfail. Minis are good at that.
Having said tha, single circuit brakes were around for a long time before the dual circuit and legendary mini heroes like Paddy Hopkirk, Rauno Aalternen and Bob Holden had complete trust in the single circuit brakes.
A down side of the dual circuit is that its fairly difficult to fit a booster on just one circuit and have even hard braking.
Disk brakes use different sized wheel cylinders on the rears and probably have a different pressure limiting valve. Others on here should be able to give you specific change over information for wheel cylinders etc.
I simply bolted a set of 7.5 inch discs on my mini and made no other changes and found the brakes were very good. I do not run a booster but i am not super sprinting or caning the car.
Author:  drmini in aust [ Fri Jan 06, 2006 6:46 pm ]
We've got 2 Minis with S front discs, one has a Cooper S M/C and the other the late Clubby tandem one.
Brakes work the same on both, but I needed to fit Cooper S rear wheel cylinders (5/8" dia) to both cars, to stop the rears locking during panic braking..
If you must have a servo (booster), just fit it to the front circuit. :wink:
Author:  blumin [ Sat Jan 07, 2006 9:52 pm ]
Post subject:  Dual Circuit Brakes
I know the good Dr posted this before :lol:
Where do you get rebuild kits for these?
Are the plastic reservoirs still available?
What does the s/w on the side do, are they still available?
Blue
Author:  drmini in aust [ Sat Jan 07, 2006 10:02 pm ]
Post subject:  Re: Dual Circuit Brakes
Blue
Clubby tandem M/C rebuild kit is `PBR? K7800X, I got from B&R Brakes but any brake shop can get. Made in Oz. Price is around $35.
Unsure about plastic reservoir availability, or the switch.
Switch is for brake fault dash lamp I think... ours is not hooked up (it's in a roundnose).
Author:  blumin [ Sat Jan 07, 2006 10:18 pm ]
Thanks Doc
Blue
