It is currently Mon Jul 21, 2025 10:16 pm
 Post subject: What next?????
PostPosted: Wed Mar 24, 2004 9:54 am
Hey guys im bored at work so i thought id just chuck this into the mix.
My car at the moment has an A+ 1275 with a stage 1 kit installed. Im just wondering what would be the next step to upgrade its performance in regards to the engine ie twin SU's, machined head?? Keep in mind im on a tight budget!!
have a good day!!
 Post subject: Re: What next?????
PostPosted: Wed Mar 24, 2004 10:40 am
have a good day!!
go head work , get it ported n polished , bigger valves etc
lookin for another clubby
PostPosted: Wed Mar 24, 2004 10:48 am
Adding a mild cam aswell as some head work (port it and raise CR) would probably do wonders. Upgrading the carb at the same time (either single HS6 or Weber?) might be needed as a single HS4 might not be up to the job.
Anto.
PostPosted: Wed Mar 24, 2004 12:39 pm
defenetley do the head and instead of a cam as this is $$$$ to fit try to get a good set of roller rockers fited.say 1.5 or 1.7 items....most roller rockers act like a cam anyway or so ive been told.you should get better top end again so ive been told...
PostPosted: Wed Mar 24, 2004 1:21 pm
port but DONT polish.
polishing is a myth people!
i've been told by a head specialist that it makes the petrol stick to the sides of the valves but when it's rough it makes the petrol go straight through.
PostPosted: Wed Mar 24, 2004 2:49 pm
Big valves, cam and HIF44.
PostPosted: Tue Jan 10, 2006 8:47 pm
Yeah definitely, or even a 45DCOE.
PostPosted: Tue Jan 10, 2006 8:51 pm
have a good day!!
Hey Kasper! how about a full page rendition of your avatar, just to keep us all thinking what it all is really about :roll:
PostPosted: Tue Jan 10, 2006 8:53 pm
I was wondering where willy was.....oh there he is, digging up 2 year old posts! :shock: :lol:
Website: www.justanothermini.com
PostPosted: Tue Jan 10, 2006 9:02 pm
:wink: Seeing if any bastard would notice :)
I never look at the post dates, but dug this old one up for kicks and giggles.
 Post subject: Next
PostPosted: Tue Jan 10, 2006 10:27 pm
What do you call stage one kit?
Next step
Mild port job ie match the inlet ports to the manifold (big ports don't work unless you
want to pull 8000 rpm all day + you loose too much down low)
Reshape the combustion chambers as per Vizard's book
Fit 35.5mm inlet valves & Coopr S type valve springs (S&W are good)
Carb 1 3/4 is fine (thinking of $$$ here)
Caution: don't just try & fit higher ratio rockers, you could end up with valve
spring crush, & when valve springs break, very nasty & expensive
IMOP a 45mm weber is too big for a mild 1275
Blue
Keep shiny side up
PostPosted: Wed Jan 11, 2006 10:07 am
wow, that is an old post dig up, well things have changed since then!! its all about forced induction now!! (supercharged not turbo :))
PostPosted: Wed Jan 11, 2006 10:17 am
doing a gadgets eh willy :roll:
