It is currently Tue Aug 05, 2025 2:56 pm
 Post subject: spacers for new wheels?
PostPosted: Wed Jan 25, 2006 5:54 pm
i have got some new 10" by 4.5" wheels and i was wondering do i need "spacers" to fit them onto my mini clubman?
PostPosted: Wed Jan 25, 2006 5:56 pm
You'll need to give us a bit more info Andrew , what type/size/offset of wheels ? The back is where you normall have trouble , put one on and see if it rubs on the shock absorber , if it does , get some widened brake drums rather than seperate spacers .
PostPosted: Wed Jan 25, 2006 6:04 pm
type: kidney bean.
size: 10" by 4.5"
offset: i don't know what that is.
thanks for the advice. i'll try and fit the back ones,...mabey, if i can. i thought it was the back ones i needed it for.
PostPosted: Wed Jan 25, 2006 6:12 pm
The old kidney mags (aka jellybeans) are designed for early Mini drums. So they will fit fine with flat drums, or the later spacered ones. if the latter, you WILL need flares.
I have a set on Barney, with S brakes and spacer drums. They are just legal with S flares. :wink:
PostPosted: Wed Jan 25, 2006 6:13 pm
Ah yeah , I missed the 10 x 4.5 bit :oops: , my bad ..... They should fit without any problems at all , definitely no worries on the front since your's is all standard , the backs maybe depending on the size of your rear shocks . I'd say 90% sure they'll fit without rubbing and will look great .
PostPosted: Wed Jan 25, 2006 6:17 pm
i'm gonna need flares to be legal :roll: ? beter get out the debit card.
PostPosted: Wed Jan 25, 2006 6:25 pm
What model Clubby? Common ones with 3.5" wheels had flat drums, = OK.
Clubby S with 4.5" wheels had spacered drums = need flares.
PostPosted: Wed Jan 25, 2006 8:44 pm
just got back froma drive. gotta love it! 8)
thanks for the specs Doc.
