It is currently Fri Jul 18, 2025 9:04 pm
 Post subject: Carpet
PostPosted: Mon Jan 09, 2006 6:03 pm
How much surface area do you think there is on the inside of a mini not including the roof.
My plan is to strip the inside of the car completely(already mostly done except the back seat) and just put carpet everywhere just to make it look alot neater then it looks at the moment
Right now its just baremetal and looks really dirst so im going to clean it all up and just put carpet up the walls and inside the door pockets n stuff.
Anyone know how many square meters of carpet ill be looking at.
Thanx
PostPosted: Mon Jan 09, 2006 8:15 pm
i used 4sqm on my mini (2m length x 2m wide roll) to recarpet the whole floor and firewall, still had a little bit left over, but by the sounds of it you'll need an extra metre or so. Check out monster mini's interior in the members gallery, he's used a better material than carpet on the rear bins etc and its come up a treat. Way better than if you used carpet on the same place IMO.
PostPosted: Mon Jan 09, 2006 8:38 pm
ok so what are the firwalls lol
i take it its up the sides of the car or something
and thanx for the info atleast someone is replying.?
PostPosted: Mon Jan 09, 2006 8:41 pm
resident alien
resident alien
Firewall = the sheet of metal between the motor and you :D
PostPosted: Mon Jan 09, 2006 8:59 pm
ahhhhhhh k thanx
lol
yeah i want all that carpet aswell
that furry stuff monster has is sick
i wanna get it in black and just do everything
roof n all:P
PostPosted: Mon Jan 09, 2006 9:00 pm
also do i just put the carpet down and glue it
or do i have to put something between the fabric and the metal?
PostPosted: Mon Jan 09, 2006 9:07 pm
resident alien
resident alien
Put some soundproofing. There a few different types. Here's one thread on it - http://www.ausmini.com/forums/viewtopic.php?t=7682
PostPosted: Mon Jan 09, 2006 9:25 pm
ok that didnt really help but thanks anyways
i need to know what to put under the carpet and how would i do that do i just use a shitload of glue or what?
and do i put this soundproofing stuff under all the carpet im putting in and how do i make it all tight if i do this
like so when i touch it its firm and not loose :S
PostPosted: Mon Jan 09, 2006 9:44 pm
resident alien
resident alien
Here's a few more, I didn't read them so I don't know what you'll get :D
http://www.ausmini.com/forums/viewtopic.php?t=3740&highlight=proofing
http://www.ausmini.com/forums/viewtopic.php?t=11068&highlight=proofing
http://www.ausmini.com/forums/viewtopic.php?t=6538&highlight=proofing
http://www.ausmini.com/forums/viewtopic.php?t=1485&highlight=proofing
PostPosted: Mon Jan 09, 2006 11:35 pm
All I did was put a layer of soundproofing straight onto the floor and on top of that the carpet. There is no need for any glue if you use proper automotive carpet which from memory was around $20 for a 1mx2m legnth. The carpet is pliable and will come out nice and straight if you cut it right.
off to NT I go
PostPosted: Tue Jan 10, 2006 9:14 am
For glueing carpet to the firewall, rear pockets etc I would use something like quickgrip (a contact adhesive) you can get it from all sorts of places (kmart, mitre10) the cheapest I found was a building supplies wholesaler, it was a lot cheaper.
I wouldn't be putting sound proofing under the carpet for vertical bits (firewall) this means you would have to glue the sound proofing and then glue the carpet to the soundproofing which is just asking the sound proofing to split and have your carpet peel off :x
IMO on vertical bits glue the carpet straight to the painted metal if you need it quieter still you might have to work out some sound proofing for inside the engine bay and or spray the sound deadener stuff on the outside.
Put sound proofing / underlay on the floors it blocks out stones hitting the floors and is softer for your feet. :D but don't glue it down just lay the underlay down and the carpet on top it stayed put for me. :wink:
Roads need more corners
