It is currently Sat Jul 19, 2025 1:06 am
 Post subject: flywheel nut
PostPosted: Mon Jan 09, 2006 11:30 pm
was just wondering, is it normal for the flywheel nut to be spot welded on? I assume it isn't but I am a noob :wink:
Anyway, if I am somehow able to get it off, does anyone in Adelaide have a flywheel puller I could borrow? Steve maybe?
off to NT I go
PostPosted: Tue Jan 10, 2006 12:58 am
thats not spot welded on, its just a little noob at the end,
should come right of woth the right size spanner and some muscle..
i dought steve would borrow his tools out to people,
but ask him anyway, make sure he is in a good mood or drunk tho :P
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Tue Jan 10, 2006 5:23 am
should be a 1 1/2" socket same as ya ball joints.
PostPosted: Tue Jan 10, 2006 7:43 am
Buy a socket. I think mine was $20. You will need it more than once!!! Try to get one with a 1/2" drive, otherwise you will need a reducer from 3/4" to 1/2" drive.
Website: www.justanothermini.com
PostPosted: Tue Jan 10, 2006 10:20 am
It's not welded on and it is a special bolt, not a nut.
It's tightened to 120 lbft so you will need an 1 1/2" AF socket and a long breaker bar to loosen it and then the flywheel puller to get the flywheel off.
You need to stop the whole flywheel assembly from turning whilst you undo the bolt. Jam a screwdriver in the ring gear teeth through the starter motor opening in the flywheel housing.
Then depending on how it was tightened last time it may be easy or hard to get it off. If the bolt was overtightened last time it can be near impossible to get it off.
Good luck.
RonR
 Post subject: Flywheel
PostPosted: Tue Jan 10, 2006 10:49 am
If the flywheel won't come off with just the puller, try tapping it with a BFH through
the starter motor hole, if it still does'nt move, try a bit of heat on the flywheel, it should
come off with a bang noise.
Remember, no1 & no4 pistons must be on TDC otherwise the split washer behind the flywheel can fall out & jam everything & that's nasty
Good luck
Blue
Keep shiny side up
PostPosted: Tue Jan 10, 2006 11:33 am
Use also an old main bearing shell in the flywheel to lock it in place - I have never had one slip once.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Tue Jan 10, 2006 11:38 am
Best thing I bought for my car was a 1 and 5/8 inch socket.
Fits everything:
Disc brake CV nuts
steering wheel
flywheel nuts
some other large nuts on the other end of the engine.
Also takes a good battering when it's needed as a spacer! :D
PostPosted: Tue Jan 10, 2006 11:47 am
Fits everything:
Disc brake CV nuts
steering wheel
flywheel nuts
ummmm, how'd you manage all of those with an 1 5/8 Aaron??
disc brake CV nut is 1 5/16", as is the steering wheel and the harmonic balancer bolt, and flywheel is 1 1/2"
unless someone has been at ALL of your parts with some wierd size bolts/nuts... ?
PostPosted: Tue Jan 10, 2006 11:48 am
Sorry, my mistake, I used a 1+5/16 like you mentioned.
:lol:
PostPosted: Tue Jan 10, 2006 12:17 pm
thanks heaps for all your replies, that's what I love about this forum, you can find out exactly what you need to know every time.
cheers all! :D
Nunny
off to NT I go
