Rough Revving
https://www.ausmini.com/forums/viewtopic.php?f=2&t=1480
Page 1 of 3
Author:  cush [ Tue Aug 10, 2004 12:21 pm ]
Post subject:  Rough Revving
I've been a good boy to my little lame mini, i've been giving the engine a run every now and then while it's not going anywhere and i've noticed somethin strange with the way the car revs..
if i slowly apply pressure to the go faster pedal (rev faster in my case:() the revs will raise accordingly ie.. smoothly
however,
if i stick my foot to the floor, the engine will splutter for a few moments, then gather itself and rev like i expected it to
a couple of times it gave a little puff back out the mouth of the carb.
anyone got any ideas
also, i'm trying to figure out which cable (throttle/choke) goes to which er.. turny thing :roll: for some reason i have the suspicion that they are hooked up the wrong way round, i've read a bunch about su's but ,typically, forgotten everything when i need the info. should the butterfly be connected to the throttle cable? and again, typically, i can't remember which one (on mine) connects where. .:)
and i don't have any pics...great.. so would the behaviour above be cosistent with what i suspected or is there something else...
phew... long post... i'm just waiting for the "That's what mini's do" response.. :)
thanks
michael
Author:  min13k [ Tue Aug 10, 2004 12:36 pm ]
the choke is towards the rear of the carby and the throttle is towards the front closest to the head
the oil could be a lil thick the stammer as reved hard
makka
Author:  Lillee [ Tue Aug 10, 2004 12:42 pm ]
"Puff from the carby" you been it's backfiring? if it's backfiring at the carby it's too rich... Or is that the other way around?? ermm...
anyway...
I have an acceleration "flutter" when my jet is set too rich... I lean it up one flat and it went away. Check your dashpot oil.
Pull out the sparks and see if it is running too rich.
Author:  J_A_M [ Tue Aug 10, 2004 12:44 pm ]
is the timing ok?
Author:  cush [ Tue Aug 10, 2004 1:04 pm ]
mini13k... here's something to giggle at.. it's the one that when you turn it. it turns the other... right.. :)
jam.. i have no idea :) but it sounds like that might be it
cheers guys...
Author:  min13k [ Tue Aug 10, 2004 1:27 pm ]
um ....................................................................?
makka
Author:  cush [ Tue Aug 10, 2004 1:29 pm ]
makka obviously the whe you pull the choke cable it slighty opens the butterfly... that would be the right one.... :)
<edit> hmm thinks that's not how the su works :)
Author:  min13k [ Tue Aug 10, 2004 1:36 pm ]
your not as stupid as you make out are you
makka
Author:  cush [ Tue Aug 10, 2004 1:38 pm ]
i'll just take that as a compliment and carry on living in blissfull ignorance..
Author:  min13k [ Tue Aug 10, 2004 1:51 pm ]
lol
Author:  cush [ Tue Aug 10, 2004 1:52 pm ]
so... i think i've given myself something to work with...
tune the fugger....
Author:  min13k [ Tue Aug 10, 2004 1:54 pm ]
ahhhh grasshopper i think you are starting to learn the way of the mini
Author:  cush [ Tue Aug 10, 2004 1:56 pm ]
i'm just looking for the mixture screw now :)
:roll:mustbuymanualmustbuymanualmustbuymanualmustbuymanualmustbuymanualmustbuymanual :lol:
Author:  min13k [ Tue Aug 10, 2004 2:00 pm ]
got few here $10 each
makka
Author:  cush [ Tue Aug 10, 2004 2:12 pm ]
43 bux postage? :)
what year ranges have you got?
i've got a 64 body with mid 70's engine
Page 1 of 3 All times are UTC + 10 hours
