It is currently Tue Jul 22, 2025 6:19 am
 Post subject: Pushrods and head studs
PostPosted: Tue Jan 10, 2006 7:49 pm
it is recomended to replace the pushrods and headstuds when doing a Recond/ heavily Moded Engine isnt it. where can U get high performance Pushrods and head studs? can u get the pushrods coated in some sort of low firction high tolerance powder coating?
Anyways
Regards
Darken
Anysort of info Links or anything would be great.
PostPosted: Tue Jan 10, 2006 9:30 pm
As far as i'm aware there isn't any inherent weakness in the pushrods...i would think they are tough little buggers and you are wasting your time looking down that path..
Head studs, i would look at ARP stuff...
PostPosted: Tue Jan 10, 2006 9:40 pm
just talking to Graham Russel last week about same for 1380.
he said - pushrods OK use what came with the engine
- rod bolts and head studs/nuts - ARP available from Rocket Industries
- rod bolts or head studs (can't remember which they did and did not have) Mini Spares UK ones avaliable form Minisport SA in Adelaide
PostPosted: Tue Jan 10, 2006 9:47 pm
How's that engine coming along mick?
PostPosted: Tue Jan 10, 2006 10:04 pm
on hold till i get the crankshaft from Cody tested and ground.......
PostPosted: Tue Jan 10, 2006 10:16 pm
Mick when I measured it before I'm pretty sure it was -010/010 and didn't need a grind. Spiro will advise.. 8)
PostPosted: Tue Jan 10, 2006 10:58 pm
another great subtle hijack guys :lol:
Spiro will advise i am sure, but my instructions are to do it once and do it right, so if it looks like a grind, then that's just fine.
Thanks anyway Kev, i'm just looking forward to being able to use it again, its been 12+ months for that car now. :roll:
michael
PostPosted: Wed Jan 11, 2006 7:03 pm
hey cheers Fellas,
what about the headstuds off the Mini spares On ebay.?? has anyone used them b4?
PostPosted: Wed Jan 11, 2006 7:42 pm
Headstuds are headstuds, there are no known problems with original BMC/Leyland studs (apart from the crap head BOLTS that BMC Aust used on some 1098s).
MiniSpares studs would be OK, I'm pretty sure KC said he uses them in his engine builds.
ARP head studs are nice, but probably overkill for road cars.
But 1275 rod bolts & nuts... don't trust them, unless you know their history.
Chong has a 1275 motor which is an excellent example of what happens when its PO built a new motor with old bolts..
one let go and totalled it. All that was any good after was 3 rods and pistons, and the main bearing caps... :cry:
PostPosted: Thu Jan 12, 2006 5:36 pm
so The pushrods Should be fine Even If they havent been changed in 30 odd years wouldnt they wear out On a Angle?
PostPosted: Thu Jan 12, 2006 6:41 pm
All that seems to happen with pushrods it they wear a little `tit nipple' in the middle at bottom, where they sit in the cam follower. Just touch it gently on a grinder to flatten `tit' off. :lol:
