Besser wrote:
Have to agree with SSKN...
A newer engine lasts longer and has more scope to modify then a A or A+
A newer engine may last longer, but i think your pushing your luck to say that a EJDE has more scope for modication than the 40+ years of development and modifications that the A-series has behind it...
Besser wrote:
Alloy heads dissapate heat better then cast iron so you can run higher comp (or boost)
...alloy heads also warp easier and he's obviously not going for outright performance, sounds like he just wants something a little more modern, more reliable..
Besser wrote:
Gear box design has ment 5 speeds instread of 4 and the changes are better.
Ok the extra gear is nice, but better changes? there is nothing to complain about with a well built mini box, they have great feel and especially in remote guise crap all over stock econo jap slug boxes in terms of feel...
Besser wrote:
It runs smoother and quieter.
If you want smoother and quieter, go buy some luxury car, half the fun of driving a car is a aural pleasure. I'm going down the starlet route and it's certainly going to make as much noise as my A-series when i'm through with it..
Besser wrote:
If you wanted a full house road 1275 A series then 3-5K is the price range and for that you could almost do a new motor conversion.
You're looking at 6-10k not accounting for any big blowouts in budget to complete a conversion properly, ask people who are currently doing them..it's effectively twice what it would cost to rebuild the a-series.
The point i'm trying to make is that if your after big horsepower 150-200+HP then a conversion makes sense because of the extra reliability and it's much cheaper to get that kind of power. Lets face it, the a-series would not last a year in that state of tune if driven regularly.
But if all your after is a bit of economy, not much extra power, then i say why bother with it? You can get easy and reliable power out of the a-series provided you don't go for those nutter outputs as above. It'll be far cheaper, just as reliable...I mean a stock 1275 makes that kind of power and would run forever..
/rant
