Carpet Clips
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14902
Author:  Foley [ Thu Jan 12, 2006 5:44 pm ]
Post subject:  Carpet Clips
With my mini theres clips around the outside of the cabin on the inside.
Are these for carpet? If they are do you think i should pull them out and just put the carpet in there so ya cant take it out again.
Author:  Bromley [ Thu Jan 12, 2006 8:21 pm ]
If they are little round push stud clips, then yes they are for carpet (so I have been told). I don't use mine because the carpet tucks in under the kick panel things.
Author:  Mike [ Fri Jan 13, 2006 6:38 am ]
There should be 2 of them on each side - you'll need the female clip that goes through the carpet if you want to be able to use them. A complete set is a couple of pounds from minispares UK. Otherwise just leave them there covered by the carpet, they are completely hidden.
Author:  Foley [ Fri Jan 13, 2006 10:36 am ]
sweet thanx
my dad said to use them but i really wanted that clean edge look.
also anybody know how to put the carpet down, like under it i put some sound deffener or somthing like that.
then do i jus glue the carpet down or what canuse the way im looking at it the carpet will be really loose if i just glue it. How do i make it so the carpet is real firm.
Author:  69 red dwarf [ Fri Jan 13, 2006 4:56 pm ]
tell it it looks fat?
dont bother glueing if it is under the kick panels it will mould to shape
that seems to be the way to go
Author:  Foley [ Fri Jan 13, 2006 6:23 pm ]
what exactly is the kick panel.
and what do i do with the windows like i want the carpet to go up to the windows and on the roof aswel how do i neaten it up around the windows. does it just tuck up under the window seals or what?
