MiNi MuLiShA wrote:
Beefa wrote:
Why bother? If you want a roundie front buy a roundie...solves all hassles, confusion etc. If you want a Clubby body buy a clubby
Waste of time and money
ahh the voice of the in-experienced, what can i say.
The fact that you get burst proof locks, better heaters (IMO) padded dash etc etc. Why would you go and spend hundereds on clubman panels to fix the beaten front if you had a perfect roundie for panels in the backyard that had been hit up the back.... i mean, if your going to paint it anyway, who cares really, the only time where theres going to be an extra cost, is when you buy the clubby panels as you suggest.
I dont mind the clubman rear lights, you have the options open you wish to put in clear or different colored lenses, as all mk3 onwards minis had, some suggest clubmans (certain years) had better rust prevention measures than the early roundies, clubmans being later model, more often than not have done less kms(miles) than earlier cars so that in it selfs another pro.
-Cam
I may be inexperienced but I know from owning a Clubby they arent as 'better' as you suggest.
The roundies IMO have better door locks, the clubbies have crap inside door handles, heaters only work when they want to and the rust in the earlier clubbies is worse then the roundies (I know this from Junior and Beefa).
If you put the roundie front on a clubby, you will need to get it engineered and an engineers certifcate which could and most likely will be more then the bonnet, 2 side panels and a bumper off another clubby.
Its easier for the person if they either buy another clubbie or fix the front of the smashed car.
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
