It is currently Sat Jul 19, 2025 12:36 pm
 Post subject: Carpet Clips
PostPosted: Thu Jan 12, 2006 5:44 pm
With my mini theres clips around the outside of the cabin on the inside.
Are these for carpet? If they are do you think i should pull them out and just put the carpet in there so ya cant take it out again.
PostPosted: Thu Jan 12, 2006 8:21 pm
If they are little round push stud clips, then yes they are for carpet (so I have been told). I don't use mine because the carpet tucks in under the kick panel things.
PostPosted: Fri Jan 13, 2006 6:38 am
There should be 2 of them on each side - you'll need the female clip that goes through the carpet if you want to be able to use them. A complete set is a couple of pounds from minispares UK. Otherwise just leave them there covered by the carpet, they are completely hidden.
PostPosted: Fri Jan 13, 2006 10:36 am
sweet thanx
my dad said to use them but i really wanted that clean edge look.
also anybody know how to put the carpet down, like under it i put some sound deffener or somthing like that.
then do i jus glue the carpet down or what canuse the way im looking at it the carpet will be really loose if i just glue it. How do i make it so the carpet is real firm.
PostPosted: Fri Jan 13, 2006 4:56 pm
tell it it looks fat?
dont bother glueing if it is under the kick panels it will mould to shape
that seems to be the way to go
ook!
69 mini k
PostPosted: Fri Jan 13, 2006 6:23 pm
what exactly is the kick panel.
and what do i do with the windows like i want the carpet to go up to the windows and on the roof aswel how do i neaten it up around the windows. does it just tuck up under the window seals or what?
