It is currently Sat Jul 19, 2025 10:34 am
 Post subject: Holes in Mini K floor
PostPosted: Sun Jan 15, 2006 1:28 pm
Hi
I have 3 holes (about 1/2" dia) in the main floor cross beam seams at the tunnel. 2 forward and 1 at the back near the handbrake mounting.
No they are not rust, they look like they are meant to be there.
Does it have something to do with the fact that the engine/box is clubbie not Mini K.
Fill them with rubber grommets? Opinions please
I was going to attempt to supply pics but the batteries were flat.
Thanks
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Sun Jan 15, 2006 1:35 pm
Obviously you have a rodchange box in it now. Those holes are for the Mini-K rear remote mounting bracket. :wink:
PLEASE don't weld them up (like PO of ours did... :x ) in case you want to fit the proper 4 synchro remote box sometime- just put 3 short bolts & nuts in. 8)
PostPosted: Sun Jan 15, 2006 1:45 pm
Thanks Doc
I thought that must be the case and no I won't have them welded up.
But why not some grommets? I thought they won't go rusty like nuts and bolts
Nigel
75 Clubman
PostPosted: Sun Jan 15, 2006 3:40 pm
Nuts and bolts don't go rusty back there.. it's pretty protected.
Grommets- OK if U got em... :wink:
Users browsing this forum: Google [Bot] and 98 guests
