Tryin to remove shitty head gasket! https://www.ausmini.com/forums/viewtopic.php?f=2&t=15009 |
Author: | =twista= [ Sun Jan 15, 2006 2:09 pm ] |
Post subject: | Tryin to remove shitty head gasket! |
What is the best way to get those old sticky head gaskets off??? |
Author: | Hagar [ Sun Jan 15, 2006 2:19 pm ] |
Coffee/tea/XXXX, Stanley knife blade in a scraper handle...patience and care... If you're like me, you'll loose it and start throwing things if you're not in the right mood before you start. |
Author: | sports850 [ Sun Jan 15, 2006 2:25 pm ] |
An old wood chisle with a reasonably sharp , but not razor sharp blade , is good , you can put some force into the handle safely , just keep pushing away from yourself though ..... |
Author: | drmini in aust [ Sun Jan 15, 2006 3:49 pm ] |
I use a new 3/8" square HSS toolbit, held at a slight angle... For real stubborn ones, a straight (not cup) twistknot wire brush on angle grinder... Don't use it on the pistons though- leave `em down the bore. ![]() Take all the head studs out first, and check there's no burrs around the holes. If there are- countersink holes with a csk drill bit, or file gently. |
Author: | =twista= [ Sun Jan 15, 2006 4:12 pm ] |
thanks Doc, and thanks to the other fellas. worked a treat! |
