It is currently Sun Jul 20, 2025 4:52 am
PostPosted: Sun Jan 15, 2006 2:09 pm
What is the best way to get those old sticky head gaskets off???
Image Image
PostPosted: Sun Jan 15, 2006 2:19 pm
Coffee/tea/XXXX, Stanley knife blade in a scraper handle...patience and care...
If you're like me, you'll loose it and start throwing things if you're not in the right mood before you start.
PostPosted: Sun Jan 15, 2006 2:25 pm
An old wood chisle with a reasonably sharp , but not razor sharp blade , is good , you can put some force into the handle safely , just keep pushing away from yourself though .....
PostPosted: Sun Jan 15, 2006 3:49 pm
I use a new 3/8" square HSS toolbit, held at a slight angle...
For real stubborn ones, a straight (not cup) twistknot wire brush on angle grinder...
Don't use it on the pistons though- leave `em down the bore. :wink:
Take all the head studs out first, and check there's no burrs around the holes. If there are- countersink holes with a csk drill bit, or file gently.
PostPosted: Sun Jan 15, 2006 4:12 pm
thanks Doc, and thanks to the other fellas.
worked a treat!
Image Image
