Driveway delima! https://www.ausmini.com/forums/viewtopic.php?f=2&t=15073 |
Page 1 of 2 |
Author: | MiniMe87 [ Mon Jan 16, 2006 4:30 pm ] |
Post subject: | Driveway delima! |
Hey all, I'm currently in the search for a mini, although i just realised i might have an issue getting it over my driveway! ![]() I'm located at Rydalmere and i was just wondering if there are any good samaritans out there that use Victoria Rd, that would be able to drop by my house and drive over my driveway, it would be greatly appreicated so as to save me buying a car i can't get into my driveway! Im in between uni and school so im available pretty much anytime, just PM me if you can! Thanks all for your help! Craig |
Author: | h0nk [ Mon Jan 16, 2006 5:17 pm ] |
Sorry don't travell that way much... but I'm sure there are some people around that do that will be willing to test it for you... I'm just wondering what it is about your driveway that you don't think a mini will be able to drive up it? |
Author: | Mini Mad [ Mon Jan 16, 2006 5:40 pm ] |
I doubt you will have any problems as long as the car hasn't sagged alot of been lowered substantially. Mini's are not that low stock, with the original suspension they actually had a lot of clearance. That said, most are sitting low these days, but you could always put hi-lo's in and raise the car a bit if you have any trouble. |
Author: | h0nk [ Mon Jan 16, 2006 5:59 pm ] |
Mini Mad wrote: you could always put hi-lo's in and raise the car a bit
but you don't want to get a clubby.. get something with hydro bags (roundie ![]() |
Author: | Mini Mad [ Mon Jan 16, 2006 6:00 pm ] |
don't discriminate, there are hydro clubbies too ![]() |
Author: | speedy [ Mon Jan 16, 2006 6:10 pm ] |
I'm with minimad, a mini should be able to go most places where a normal car (provided its driven carefully). My parents have a drop as the driveway meets the street that I used to regularly scrape with the chin of my stock VT Commodore Acclaim (clenches butt cheeks just retelling the story :X ![]() I have not scraped it once in the mini, partly due to the fact that there is no dozing off when driving the mini. |
Author: | Molina [ Mon Jan 16, 2006 6:15 pm ] |
So long as there's not major hump in the driveway then a mini will be fine. The wheels are quite close to the front and rear of the car so there's not much of an overhang. They can therefore go into some deep dips but not high humps. I'm sorry for my description. I can't make it any clearer easily. Hope you understand. ![]() |
Author: | MiniMe87 [ Mon Jan 16, 2006 8:51 pm ] |
Thanks for all the advice! The driveway raise's maybe 5-8cm from the road hieght then drops away, and most cars that drive in do scrape (mazda 626/current car hits on the exhaust flange) as well as my brothers VL commodore, and nissan pulsar (old car). So i'm a bit hesitant because i dont want a project which scratches every time i drive it out!! Thanks for all the help everyone!!!! |
Author: | 69 red dwarf [ Mon Jan 16, 2006 9:11 pm ] |
ull bang the gear box before anything else(leaking hydro on my car scratches on small speedhumps) have u tried the half brick or pice of wood trick? |
Author: | Mini Mad [ Mon Jan 16, 2006 9:29 pm ] |
I find that if you go on an angle it's pretty hard to scrape the gearbox casing unless you drive square on with anything. Have the front wheels in line with the gearbox means that if you take anything you may hit on an angle raising one wheel will enable you to clear the gearbox. I think the most common item bottoming out is the exhaust system if it hasn't been tucked away nicely.. |
Author: | czerial [ Mon Jan 16, 2006 10:20 pm ] |
Ask betty, she lives in parra ![]() or if you wanna wait till uni goes back i will be there all the time ![]() |
Author: | MiniMe87 [ Tue Jan 17, 2006 6:58 am ] |
hey chris, I'm going to be driving past your place pretty much every day to, im going uts! Thanks ill send her a PM Thanks all |
Author: | jess87 [ Tue Jan 17, 2006 9:32 pm ] |
Post subject: | Our devil driveway |
Hey MiniMe87, My dad made these big hills in our driveway to prevent the road from washing away then it rains. Jeremy gets over them alright... just shakes up my breaky a bit. So i recon you will be right ![]() Jess |
Author: | Betty [ Tue Jan 17, 2006 11:05 pm ] |
hey craig! i am mroe than happy to drive over your drive way... betty will probrably scrape but we will see hey? give me a call! |
Author: | Mini Mad [ Tue Jan 17, 2006 11:40 pm ] |
