Drum Brake Overhaul. https://www.ausmini.com/forums/viewtopic.php?f=2&t=15076 |
Page 1 of 2 |
Author: | Maxi23 [ Mon Jan 16, 2006 4:59 pm ] |
Post subject: | Drum Brake Overhaul. |
Looking to overhaul my braking system within the next week or two. As Im toping up my master cylinder every 2 or 3 days.....not safe... What Im after is a list of things I might need in the overhaul. (Not after brake drums themselves) What I have in my possesion so far : Front Drum Pads Brake Hoses What I know I need : 6 x Cylinders (4 for front, 2 for rear) 1 x Master Cylinder Now, what small bits will I need to also purchase ? eg new adjusters, gaskets etc etc Any ideas people ? Thanx. |
Author: | h0nk [ Mon Jan 16, 2006 5:10 pm ] |
I think thats about all you need.. theres no real gaskets needed, but you usually get a small cardboard one with the cylindars... Are you going to replace your mastercylinder or just put a kit though it? might be cheaper. |
Author: | Maxi23 [ Mon Jan 16, 2006 5:19 pm ] |
Going to replace cylinder entirely. Looks very tired indeed. |
Author: | Morris 1100 [ Mon Jan 16, 2006 5:22 pm ] |
It would not hurt to replace the shoe return springs as well. Check the adjusters and replace them if they are stuffed. They may clean up and give them a coat of anti-seize. |
Author: | Lillee [ Tue Jan 17, 2006 8:49 am ] |
Definately new shoe return springs. Don't lose all the copper washers, there should be one on the screw end of every hose just about. Don't forget to put them back in either! Buy brake fluid! 2 bottles for good measure! If you buy a wheel cylinders, note that they could be 7mm beeld nipples or some odd size like that so i would check if you have a good shifter of that size or another spanner of that size. |
Author: | mini_van_1970 [ Tue Jan 17, 2006 9:07 am ] |
What about the pipes that have to be ent I mean you would have to take in the old ones to get them bent to spec but if you really wanna go all out you can replace the pipes at the front and the ones on the drum also the one to the sender unit Pat |
Author: | Dylans Clubby [ Tue Jan 17, 2006 11:03 am ] |
i know you said you didnt need drums, but just a thought...do you already have stepped drums? cos if you dont and in future if you want to fit mags...but i dont know anything about offset or how far they will push out your wheels or anything...just a thought... also, if you are cashed up and doing a complete overhaul would it be worth investing in some discs??? |
Author: | aznpride [ Tue Jan 17, 2006 11:40 am ] |
Just had the brakes on my round nose done. First time we've done brakes on a mini, quite a experience. |
Author: | 3DJ [ Tue Jan 17, 2006 12:23 pm ] |
http://cgi.ebay.com.au/MINI-DRUM-BRAKE- ... dZViewItem ![]() |
Author: | Maxi23 [ Tue Jan 17, 2006 5:40 pm ] |
Yeah, I emailed them and they put it up for me ![]() Id go discs if i wasnt heading back to uni to study next month.....so my budget can go as far s $400 for the drum brake rebuild. Im gonna give the metal piping a miss atm, cause the problems are with the cylinders, the wheels dont brake evenly at all. Prob. get the drums machined also...or buy new ones.....cant decide. |
Author: | kazjim [ Tue Jan 17, 2006 7:06 pm ] |
You Know Max, $400 would go a long way towards paying for a Van . . . I'd happily split it with you .. you take the discs, I'll take the 1275 . . . sell the Van as parts (or secretly finish it . . . he he he) Think about it . . . I"ll call Dan later this week . . . J |
Author: | min13k [ Tue Jan 17, 2006 7:13 pm ] |
hell if he aint interested i sure as hell am 400 for a set of disks ![]() then i would have a set for each car i own makka |
Author: | kazjim [ Tue Jan 17, 2006 7:17 pm ] |
Makka, watch this space . . .. I might have a complete running 1275, discs, and heaps of "bits" for sale soon . . . . maybe . . . . ![]() But max gets first dibs... being a poor uni student and all .... you and I already have discs .... ![]() J |
Author: | min13k [ Tue Jan 17, 2006 7:21 pm ] |
yeah BUT only two sets ![]() actully what i would like james is a 1275 auto block cheap so i can start traceys car after i finish the replacement makka |
Author: | Lillee [ Tue Jan 17, 2006 8:57 pm ] |
ooo me me! I am a poor Uni Student!!! |
