1100's motors? https://www.ausmini.com/forums/viewtopic.php?f=2&t=15095 |
Author: | Benmcf1 [ Mon Jan 16, 2006 8:33 pm ] |
Post subject: | 1100's motors? |
Hey guys, (and girl's sorry) i'm just looking up engine numbers and the like, and i see that according to : http://www.minis.com.au/ Ive got a 1100's motor in my van. Now i know i have heard something about them being good things to have. Is that because they are an 1100 bore in a 1275 block? and therefore are more likely to give a few extra rebuilds? Or is there some other reason? number is : 12y/Ta/h8591 |
Author: | ronniemac [ Mon Jan 16, 2006 8:37 pm ] |
1275 without the tappet plates on the back. Came out in the morris 1100. Others will fill you in more on this. |
Author: | awdmoke [ Mon Jan 16, 2006 8:41 pm ] |
The whole 1100 thing is a misnomer The 1100S actually had a 1275 instead of the 1098 It is a standard 1275 motor, which is a good thing ![]() |
Author: | Spaceboy [ Mon Jan 16, 2006 8:59 pm ] |
yeah theyre' nothing special mos't 1100's have had the'ir engine's stol'-ded for minis' |
Author: | 69 red dwarf [ Mon Jan 16, 2006 9:07 pm ] |
i was waiting for that^^ |
Author: | cush [ Mon Jan 16, 2006 9:53 pm ] |
i beleive some MOggie 1100S's (<-- is that ok, will?) had cooper S spec internals... i think the doc or morris 1100 (even simon k) will have this info ![]() |
Author: | drmini in aust [ Mon Jan 16, 2006 10:06 pm ] |
cush wrote: i beleive some MOggie 1100S's (<-- is that ok, will?) had cooper S spec internals...
i think the doc or morris 1100 (even simon k) will have this info ![]() Early ones had a small journal, crossdrilled crank with Cooper S rods, never seen one factory fitted with an S EN40B crank though. |
Author: | cush [ Mon Jan 16, 2006 10:32 pm ] |
ok.. four out of five aint bad... ![]() |
Author: | mad-mk1 [ Tue Jan 17, 2006 1:38 pm ] |
hey Benmcf1 did you recently buy that mini?? i recon i saw it advertised sumwhere, or a very similar 1 |
Author: | Benmcf1 [ Tue Jan 17, 2006 3:41 pm ] |
Ok thanks all. I guess there are some misconseptions floating around re 1100's motors. But i think the conclusion is..... On a motor that has already been recond and transplanted into another mini, then left is a shed for 7 years till the rings rust to the barrel's. There aint nothing special about it ![]() Gee i hope there is still room for a rebore. mad-mk1. I bought it about 8 months ago.. So it may be the one you saw. Was in on consighnment at Moris mania then mini sport thats all i know. I got it from the latter. |
Author: | drmini in aust [ Tue Jan 17, 2006 9:42 pm ] |
Plenty of scope for rebores on these- can get pistons in +.020", 040, 060, 094 (73.0mm) and .115 (73.5mm). Used to be able to get 74mm too but they've gone , like the dodo. ![]() |
