Rod change - 1st to 2nd gear https://www.ausmini.com/forums/viewtopic.php?f=2&t=15118 |
Page 1 of 2 |
Author: | JAM_IT [ Tue Jan 17, 2006 11:03 am ] |
Post subject: | Rod change - 1st to 2nd gear |
I find that changing from 1st to 2nd (with a rod change box only) has a long 'throw'. The speed and momentum I build up in 1st seems to be somewhat lost by the time I can engage 2nd and continue on my way. Cars seem to scream up close behind me, anticipating that I am driving a modern day, injected, smooth shifting gearbox car (or auto car) Anyone else with a rod change box have this dilema? I don't drive like a grandpa, but in saying that I do value my syncros and gearbox, and I don't throw it rapidly from one gear to another..... |
Author: | poeee [ Tue Jan 17, 2006 11:05 am ] |
I wouldn't say a "long throw" but that is because i'm used to it, I spose! I've driven Rodney's car, and he has a short shift in it. Bit wierd at first, if you are used to a normal one, but once ya get down to the first corner, it's all good! |
Author: | Mini Mad [ Tue Jan 17, 2006 11:18 am ] |
Mine is fine, goes into second quite well.. |
Author: | Mini Mad [ Tue Jan 17, 2006 11:31 am ] |
Here is a video of mine to compare.. http://users.on.net/~adslqru2/rodchange.gearchange.wmv |
Author: | JAM_IT [ Tue Jan 17, 2006 11:34 am ] |
lol...thanx Guru! Nice warning light on your dash! ![]() |
Author: | Mini Mad [ Tue Jan 17, 2006 11:36 am ] |
you think it's big enough? ![]() |
Author: | meeni [ Tue Jan 17, 2006 12:34 pm ] |
mine seems fine, but i spose its what your used to, with a quickshift on as poeee said the throw is a million times shorter, so maybe try that.. |
Author: | poeee [ Tue Jan 17, 2006 1:02 pm ] |
Mini Mad wrote:
Seems the same as mine. Is yours any different, Anton? |
Author: | JAM_IT [ Tue Jan 17, 2006 1:21 pm ] |
nah....mine is the same. I must drive like a grandpa then.... ![]() ![]() |
Author: | feralsprint [ Tue Jan 17, 2006 1:30 pm ] |
hey grandpa beep beep ![]() ![]() |
Author: | Mini Mad [ Tue Jan 17, 2006 1:31 pm ] |
haha grandpa JAM ![]() I must note that i wasn't rushing it into gear above, that's about the sweet spot for a quick gear change, i could do it really fast..but i value my synchros and 'box too ![]() No one overtakes me though ![]() |
Author: | min13k [ Tue Jan 17, 2006 2:56 pm ] |
hey anton maybe you need to "jam it" into gear BAAAAAAAAAAAAAAHAHAHAHAHAHAHAHAHAHAHAHAHA makka |
Author: | Lillee [ Tue Jan 17, 2006 3:07 pm ] |
I think it has to do with gear ratio more than the throw Anton. Mk2 Cooper S ratios are closer together in 1st 2nd and 3rd and allows you to "put em away" at the lights ![]() I find my first gear is way too short. by the time the engine is screaming it's lungs out, you're only doing 20kms/h (or at least it seems that way!) To really get away i need to rely on 2nd... |
Author: | min13k [ Tue Jan 17, 2006 3:18 pm ] |
chong you could have a morry 1100 box very very short first makka |
Author: | marcsvenson [ Tue Jan 17, 2006 3:24 pm ] |
or maybe its just the people driving around you i find that when i drive my mini people around me seem to find it necessary to drive a lot harder and faster then they probably usually do to show their superiority over a crappy little mini im sure im not the only one who finds this people in commodores etc steppng out to blast past then only slow down when they get a bit ahead |
