It is currently Tue Jul 22, 2025 3:32 am
PostPosted: Wed Jan 18, 2006 7:52 am
Hi,
I think my problem is worn bushes in the alternator - what do you think.
Last night, started the Mini up with no probs and put the headlights on.....the engine died. Started her up again and revved up a little, put the headlights on again - no probs this time, but it played up a bit when I was showing off my new driving lights to my mate.
Anyway, got home this morning and just to see what would happen, I turned on the headlights and the revs died down a little.
Alternator bushes???? What do you think????
Hooroo
Rod Image
PostPosted: Wed Jan 18, 2006 9:44 am
Its a bit more than worn bushes, the alternator is not big enough for all your lights, its normal for the revs to drop a little when you turn on the headlights, what idle speed have you set, if its to low to start with may be part of the problem and a standard mini alternator is on the limit with ordinary lights and electrics of the car, time for an upgrade
Jon
PostPosted: Wed Jan 18, 2006 6:19 pm
Cheers Jon,
I've got the "Prince of Darkness" as my alternator and it's not been serviced or had anything done since I got the car nearly 3 years ago.
Yer - seeing as I have an air horn and 100 watt Driving lights which I never get a chance to use - it's time to upgrade to something with a bit of umph!!!!
Hooroo
Rod Image
 Post subject: Bushes ??
PostPosted: Wed Jan 18, 2006 10:05 pm
Guys, there are no Bushes in an Alternator. What you mean is Brushes.
I can sell yous a Bosch 85 amp alternator Kit ....
