Small problem with electrics https://www.ausmini.com/forums/viewtopic.php?f=2&t=15165 |
Author: | Rodney [ Wed Jan 18, 2006 7:52 am ] |
Post subject: | Small problem with electrics |
Hi, I think my problem is worn bushes in the alternator - what do you think. Last night, started the Mini up with no probs and put the headlights on.....the engine died. Started her up again and revved up a little, put the headlights on again - no probs this time, but it played up a bit when I was showing off my new driving lights to my mate. Anyway, got home this morning and just to see what would happen, I turned on the headlights and the revs died down a little. Alternator bushes???? What do you think???? Hooroo |
Author: | feralsprint [ Wed Jan 18, 2006 9:44 am ] |
Its a bit more than worn bushes, the alternator is not big enough for all your lights, its normal for the revs to drop a little when you turn on the headlights, what idle speed have you set, if its to low to start with may be part of the problem and a standard mini alternator is on the limit with ordinary lights and electrics of the car, time for an upgrade Jon |
Author: | Rodney [ Wed Jan 18, 2006 6:19 pm ] |
Cheers Jon, I've got the "Prince of Darkness" as my alternator and it's not been serviced or had anything done since I got the car nearly 3 years ago. Yer - seeing as I have an air horn and 100 watt Driving lights which I never get a chance to use - it's time to upgrade to something with a bit of umph!!!! Hooroo |
Author: | Convertible Mini [ Wed Jan 18, 2006 10:05 pm ] |
Post subject: | Bushes ?? |
Guys, there are no Bushes in an Alternator. What you mean is Brushes. I can sell yous a Bosch 85 amp alternator Kit .... |
