dewey wrote:
Isn't that an apples to oranges comparison? You're comparing your mates 998 which sounds like its running like its supposed to, to your 1098 which sounds like its not running anything like how it is supposed to. As Dr Mini says, there isn't much difference between the two engines. If you compare a freshly built 998 to a freshly built 1098 they should both run equally as well, with the 998 more comfortable at higher rpms and the 1098 offering a little more torque down low. Instead of saying that the 998 is a better engine than the 1098, its probably more acurate to say that your driving style is more suited to 998s... higher reving... than the 1098.
dewey
well in my experience driving a well running and maintained
(as well as you can expect an 1100 to run) 1100 everyday, and having had the chance to drive my mates 998 in similar condition.. i would choose the 998 for everyday driving duties every time without hesitation.
On the racetrack, i could live with the harshness for the bagful of extra torque.
both engines are really awful beyond 5000rpm so neither are high revving...
Well, high revving for a bus maybe!
i've heard you can use shorter pistons and that fixes the problem with severe wear on the piston rings.
