handbrake https://www.ausmini.com/forums/viewtopic.php?f=2&t=15191 |
Author: | manofaus [ Wed Jan 18, 2006 9:59 pm ] |
Post subject: | handbrake |
my handbrake used to be really crap in the mini. Since I am doing a complete makeover of my 850 how can I improve it? can you use idler wheels or something? |
Author: | Mini Mad [ Wed Jan 18, 2006 10:27 pm ] |
You can make sure your rear drums are up to scratch and adjusted properly. You can also get someone to install a hydraulic handbrake..about ~$300 |
Author: | aussie [ Wed Jan 18, 2006 11:59 pm ] |
r u looking at doing killer handbrakeys>? |
Author: | Curly [ Thu Jan 19, 2006 6:07 am ] |
I used to do a lot of motorkhanas in a Cooper S engined, little wheel moke - fun times ![]() |
Author: | sports850 [ Thu Jan 19, 2006 7:02 am ] |
Just a query on hydraulic handbrakes , are they legal for road use ? Hate to suggest it to someone and have them defected over it . |
Author: | Curly [ Thu Jan 19, 2006 8:00 am ] |
Quote: Just a query on hydraulic handbrakes , are they legal for road use ? Hate to suggest it to someone and have them defected over it.
Probably not ![]() It's also not a good idea to use a hydraulic handbrake as a parking brake. Constant pressure on the seals is not good, and if ther'e any wear on the seal the pressure will drop off and your Mini will be rolling away. ![]() |
Author: | sports850 [ Thu Jan 19, 2006 8:06 am ] |
Thank's Curly , that's what I thought but wasn't sure , I know people use them but wasn't sure if you would get through rego as we have it in NSW with it . |
Author: | MrBob [ Thu Jan 19, 2006 9:36 am ] |
Mine actually has two seperate systems. I have the original mechanical handbrake, and behind that a lever for my Hydraulic one - so they don't really interfere with each other and I don't have to leave the hydraulic one as a park brake. They cost about $450 fully installed and are a heap of fun. ![]() |
Author: | manofaus [ Sat Jan 21, 2006 1:39 pm ] |
the stock mini handbrake can be made good? should I change all the cables..? will that make a difference? what do you use for lubricant in the guides? |
Author: | min13k [ Sat Jan 21, 2006 3:47 pm ] |
redo the quadrants replace the cables as with age they strech and become elastic and cheak to see if the linings and drums are glazed makka |
