It is currently Sat Jul 26, 2025 12:57 am
 Post subject: Blinkers.............
PostPosted: Wed Jan 18, 2006 10:08 am
Hi there, I have a blinker problem, just wondering if anyone knows how to fix this problem??? The Blinkers are on constantly on the dash, but they are not on outside....When you put the the blinker on left or right they come on the dash and outside but they do not blink..So they stay solid .
When you turn the blinker off it goes back to both being lit on the dash but not outside..................................Can Anyone help.... :? :) :?
Cheers Monster Mini
PostPosted: Wed Jan 18, 2006 10:30 am
start simple...
blown bulb?
PostPosted: Wed Jan 18, 2006 11:32 am
cush how would a blown bulb allow both lights to be on???
its something with the flasher unit, not working properly or not wired correctly. as for the inside lights, they are wired the same as the outside ones, so that could be wrong, im not sure. have a look at your flasher unit if there is one.. then go from there
Potato
PostPosted: Wed Jan 18, 2006 12:40 pm
Sounds like dodgy wiring.. have they ever worked? The points inside the flasher unit can stick... replacing the flasher unit should easily fix it..
PostPosted: Wed Jan 18, 2006 4:12 pm
Hi has anyone a photo of the flasher unit ....is it the one under the dash thats about 3-4cm round looks like a little pot in alloy and has 4 green wires comming out of it.....
Cheers Monster Mini :D :) :D
PostPosted: Wed Jan 18, 2006 4:51 pm
yep that's probably it... something similar to this:
PostPosted: Wed Jan 18, 2006 5:02 pm
Hi , Is there any easy way to test if it is the flasher unit..
PostPosted: Wed Jan 18, 2006 5:28 pm
Stick a 12v test lamp on each of the wires.... test the 12v input (should be on constantly) and then test the left and right wires, when you have the blinker set to left or right respectively.. Actually before you do that, just put the blinkers on either left or right and see if you can hear the flasher unit ticking.. If theres no sound it probably needs replacing.
PostPosted: Wed Jan 18, 2006 5:47 pm
Ahh awsome
i have just had the same thing happen, i am definate mine is a flasher problem.
best place to find a replacement??
Jet Red Mini K
PostPosted: Wed Jan 18, 2006 5:54 pm
Supercheap or repco shoud have one.. just a generic flasher unit will work.. You might be able to get ones specifically for the mini from a specialist, not sure.. probably won't make much difference.. it just 'flashes'.
PostPosted: Wed Jan 18, 2006 5:58 pm
Cheers, thanks heaps for that one.
Jet Red Mini K
PostPosted: Wed Jan 18, 2006 6:10 pm
got my replacement one ordered today to pick up tomorrow from Repco, forgot to get price but they are quite cheap
PostPosted: Wed Jan 18, 2006 6:16 pm
Or if you cant fix the problem just stick a green P plate on the front and back and apparently you dont need blinkers anymore
PostPosted: Wed Jan 18, 2006 9:34 pm
resident alien
resident alien
PostPosted: Wed Jan 18, 2006 10:24 pm
Thanks Guys i will be heading off to karcraft tommorrow for a flasher unit...
Great info .......thanks a million.....
