Monster Mini wrote:
Hi i just bought some new chrome wiper bezels , we had to grind a bit of the bezel down so they would fit correctly.....the problem is the DONT cover the whole hole that the wiper arm comes out of...So the rain can come though....has anyone else had this problem.....Are there bigger bezels ....Whats the Fix ...I have put some rubber washer type covers under them ...But dont like the look of them is there somthing else????????
Cheers Monster Mini
The ones you got are the UK chromed ones, same shape as the plastic/rubber ones our cars used up to 1967. Our later cars with the recesses in the scuttle had a different shaped one, not made any more.
We need to set up and make some S/S ones...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
