It is currently Fri Aug 15, 2025 9:37 pm
 Post subject: Black smoke
PostPosted: Thu Jan 19, 2006 10:35 pm
Any solutions to plumes of black sooty smoke from exhaust - is it too rich and if so how do I fix, please help.
1977 Clubman
PostPosted: Thu Jan 19, 2006 11:34 pm
just had a quick look at choke linkage - not returning by itself fully - could this be something ?
1977 Clubman
PostPosted: Thu Jan 19, 2006 11:47 pm
Hi,
If your choke is staying on whilst your motor is on, you will almost definitely get a nice puff of black smoke out the exhaust. Sometimes you can be lucky and spray with WD or equivalent around the choke area (on the carbie) and you may free it.
Thanks
PostPosted: Fri Jan 20, 2006 12:02 am
yeh will try that tommorow - what else can i adjust to get it right ?
1977 Clubman
PostPosted: Fri Jan 20, 2006 6:59 am
You can check the choke cable moves freely and hasn't got a bend or kink in it where it goes into the outer cable .
 Post subject: Prince
PostPosted: Fri Jan 20, 2006 11:17 am
Well its definately not a Lucas Electrics problem....they use white smoke :D
PostPosted: Fri Jan 20, 2006 8:12 pm
played around with the mixture adjusting nut under the carb, it has helped a bit but not totally, what else can I fiddle with
1977 Clubman
PostPosted: Fri Jan 20, 2006 9:19 pm
Hi,
Is your timing spot on.
Thanks
PostPosted: Sat Jan 21, 2006 1:01 am
Not running nitrous are you ? The black exhaust puff is a dead give away.
smithy
 Post subject: close
PostPosted: Sat Jan 21, 2006 1:30 am
close
Users browsing this forum: No registered users and 356 guests
