HELP!!!!!! https://www.ausmini.com/forums/viewtopic.php?f=2&t=15342 |
Author: | Rikki [ Sun Jan 22, 2006 7:34 pm ] |
Post subject: | HELP!!!!!! |
i need help wiring my starter solenoid. here a pic ![]() please HELP!!! not sure where every thing goes. Cheers Rikki p.s sorry bout the size took it with my phone |
Author: | Morris 1100 [ Sun Jan 22, 2006 7:42 pm ] |
Brown wires to the battery side of the solenoid Ignition switch will go to one of the terminals on the side. Try one then the other. |
Author: | Rikki [ Sun Jan 22, 2006 8:57 pm ] |
thanks Morris 1100 i tried that but the car wont turn over. |
Author: | Morris 1100 [ Sun Jan 22, 2006 9:10 pm ] |
Is there power when you turn the key on? (Do the warning lights on the dash come on?) Does the solenoid click when you turn the key? Try running a jump wire from the battery side of the solenoid and touch it to the small terminals one at a time. It should make the solenoid click when you get the right one. |
Author: | Rikki [ Thu Jan 26, 2006 8:18 am ] |
Hey, Thanks Morris 1000, i hooked them up (found the right ones) but now when i turn the key to start it starts but the starter motor keeps going. Any ideas?? Cheers Rikki |
Author: | Mike [ Thu Jan 26, 2006 9:21 am ] |
Rikki wrote: Hey, Thanks Morris 1000, i hooked them up (found the right ones) but now when i turn the key to start it starts but the starter motor keeps going. Any ideas??
Cheers Rikki check the 4 large screw terminals for one that is only +12v when the ignition switch is in position 3 (cranking). Thats the starter terminal. |
