Is deseamed a good thing??
https://www.ausmini.com/forums/viewtopic.php?f=2&t=15421
Page 1 of 3
Author:  falcon_princess [ Tue Jan 24, 2006 11:11 am ]
Post subject:  Is deseamed a good thing??
Hi, just read an ad and it said the mini clubman was deseamed. what does it mean, and is it a good thing?? thanks guys :)
Author:  aussie [ Tue Jan 24, 2006 11:15 am ]
well you'd want to know it was done propperly :shock:
Author:  falcon_princess [ Tue Jan 24, 2006 11:17 am ]
what is it, i dont know what properly is if i duno what deseamed means... please explain thanks :?
Author:  Thorlek [ Tue Jan 24, 2006 11:18 am ]
deseaming means the seams which join panels together on the mini have been removed.
the seam is the part that protrudes from a number of areas on the mini (around the roof, and down each "corner" of the mini for example"
it can look very good if done well... similarly i can look particularly bad if not done well.
Author:  poeee [ Tue Jan 24, 2006 11:18 am ]
Looks are the only thing going for it, and even then you have to like the style.
Basically, it makes the car a little less strong. Sometimes on a de-seamed car, if it gets pranged, it falls apart.
I wouldn't recomend doing it to a car that hasn't been de-seamed, but if you are looking at a car that has had it done, make sure it was done right!
Author:  falcon_princess [ Tue Jan 24, 2006 11:22 am ]
well i really really wanna buy it this is the thread..
http://www.ausmini.com/forums/viewtopic ... 8a13789cfc
youve probably seen it, its only $450, thats why i was a bit sus bout it... what do you think??
i have the money sitting here infront of me and the car trailer, and i live close, and im willing to do it up - ive done up a 66 falcon :oops: its my bf's he has no idea lol
so now i want a lil clubbie of my own...
please help
Author:  adeee [ Tue Jan 24, 2006 11:29 am ]
A deseamed clubby:
a non deseamed clubby:
Author:  falcon_princess [ Tue Jan 24, 2006 11:35 am ]
i cant tell the difference
but i understand wat u mean i found this pic 2 --
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=windows-1252">
<META NAME="GENERATOR" CONTENT="Microsoft FrontPage 4.0">
<META NAME="ProgId" CONTENT="FrontPage.Editor.Document">
<TITLE>New Page 1</TITLE>
</HEAD>
<BODY>
<P>
<IMG BORDER="0" SRC="file:///C:/Documents%20and%20Settings/Compaq_Owner/My%20Documents/My%20Pictures/11.jpg" WIDTH="800" HEIGHT="600"></P>
</BODY>
</HTML>[/img]
Author:  Thorlek [ Tue Jan 24, 2006 11:36 am ]
As everyone has said... deseaming can be good... but it can also be very bad
If i were you i would make sure you have a really really good look at all the seams and maybe take someone along (panel beater / mechanic?) to have a look too make sure its not a crappy backyard deseaming job
Author:  falcon_princess [ Tue Jan 24, 2006 11:36 am ]
Post subject:  oops sorry
http://photobucket.com/albums/y64/FatMa ... ent=02.jpg
Author:  awdmoke [ Tue Jan 24, 2006 11:37 am ]
Personal preference - I like the look (if done right).
There have been a few discussions on this before...
Author:  falcon_princess [ Tue Jan 24, 2006 11:37 am ]
hmmm, i dont know a panel beater or a mechanic..... could i get it fixed professionally if it is a crap job?? or should i forget about it n keep lookin??
Author:  sports850 [ Tue Jan 24, 2006 12:02 pm ]
I'll put my 2 cents worth in , deseamed mini's look good and you can kid yourself that it improves the aerodynamics without too much trouble . Unfortunately , I wouldn't buy a deseamed mini unless I could remove the trim beside the rear window and see behind the other seams to see how it was done . Basically you can grind an inch of seam off at a time and weld the two panel edges together and it will most likely hold till you hit something , depends on how good your welds are as to how big a thing you have to hit for it to fall apart . Or , to do it properly you can weld a strip of metal behind the welded joins as well to tie the whole thing together . As for the panels that you can't get to from behind , best to hammer them a little flatter and weld another strip across them to bridge it as well . The seams we're talking about by the way are the ones that stick out between the front mudguard and in front of the door , the rear side in front of the fuel filler neck and behind the rear side window's , and the roof gutter . As for the one for sale that you want , from memory it's being sold with a month or two's rego left on it , does that mean it can't be registered as is because the job may not be strong enough ? I think it's being sold as a project parts car from memory isn't it (apologies to the seller if it isn't ) .
Author:  falcon_princess [ Tue Jan 24, 2006 12:15 pm ]
Ok, one last question yes or no, should i buy it is it worth it?? please make my decisiuon for me your the experts :) thanks
Author:  Harley [ Tue Jan 24, 2006 12:20 pm ]
I don't think anyone here will answer that, cause it is your decision only.
That and we dont want it to backfire on us if it's a lemon! :D
Page 1 of 3 All times are UTC + 10 hours
