Rear Side Window Seal https://www.ausmini.com/forums/viewtopic.php?f=2&t=15435 |
Author: | Monster Mini [ Tue Jan 24, 2006 3:42 pm ] |
Post subject: | Rear Side Window Seal |
Just a question , i bought a set of new rear side window seals and they seem to be to big???? do these seals come in different sizes...they are the 1 piece joined seal -no ends... Please Explain.............to fit 1970 mini. ![]() ![]() ![]() Cheers Monster Mini |
Author: | sports850 [ Tue Jan 24, 2006 3:56 pm ] |
Always a chance they could be for a later mini , once the pom's went to the internal door hinges their mini's used taller and wider rear windscreens and taller side rear window's , can you check them against a later model mini (anything with internal door hinges ) ? Other than that no ideas , where did you get them from , a local dealer or did you import yourself ? |
Author: | Monster Mini [ Tue Jan 24, 2006 4:10 pm ] |
sports850 wrote: Always a chance they could be for a later mini , once the pom's went to the internal door hinges their mini's used taller and wider rear windscreens and taller side rear window's , can you check them against a later model mini (anything with internal door hinges ) ? Other than that no ideas , where did you get them from , a local dealer or did you import yourself ?
I picked them up from Karcraft, i spoke to the guy there and he said they shoud fit ...but of course they dont...should i cut them... What do you think ,also will they leak if there cut... Cheers Monster MIni ![]() ![]() ![]() |
Author: | sports850 [ Tue Jan 24, 2006 4:14 pm ] |
Don't cut them , good chance they'll leak , ring the place you got them from and check in case they have a batch that is marked wrong or something . A mate and I drove 4 hours to a Brisbane MG specialist to pick up a windscreen for his MGA , got hom and found it wouldn't fit , 3" too wide . The whole shipment had been cut to an oversized template as somebody stuffed up the zoom factor on the computer , basically there can be problems with things , just check it's the right part number and if they have had any others with problems . How much bigger than the window opening is it ? |
Author: | Monster Mini [ Tue Jan 24, 2006 4:33 pm ] |
sports850 wrote: Don't cut them , good chance they'll leak , ring the place you got them from and check in case they have a batch that is marked wrong or something . A mate and I drove 4 hours to a Brisbane MG specialist to pick up a windscreen for his MGA , got hom and found it wouldn't fit , 3" too wide . The whole shipment had been cut to an oversized template as somebody stuffed up the zoom factor on the computer , basically there can be problems with things , just check it's the right part number and if they have had any others with problems . How much bigger than the window opening is it ?
the ones on the car at the moment are cut...i fitted one of the new ones on three sides went on and on the fourth side I got about half of it on ,so theres about 5-10 cm extra. cheers Monster Mini |
Author: | blumin [ Tue Jan 24, 2006 10:19 pm ] |
Post subject: | Window seal |
Sounds like a pommy one to me Blue |
Author: | ClubmanGT [ Wed Jan 25, 2006 2:42 am ] |
I've just replaced these on my wife's mini. Although it is a pom Mk3 with the 'big' windows, I thought that the one piece rubbers were made too big. Same as you - 3 sides on and the 4th seeming way too big. In desparation, I went back to side 1 and adjusted it so I was really squashing it into the corners and compressing it along the sides as much as possible. This worked and the rubber fitted!! It also seems to have a fantastic tight seal now and NO water comes in. |
Author: | Monster Mini [ Wed Jan 25, 2006 8:08 am ] |
ClubmanGT wrote: I've just replaced these on my wife's mini. Although it is a pom Mk3 with the 'big' windows, I thought that the one piece rubbers were made too big. Same as you - 3 sides on and the 4th seeming way too big. In desparation, I went back to side 1 and adjusted it so I was really squashing it into the corners and compressing it along the sides as much as possible. This worked and the rubber fitted!! It also seems to have a fantastic tight seal now and NO water comes in.
Thanks for that will try that as soon as i can ... ![]() ![]() ![]() Cheers monster Mini |
Author: | britishvita [ Wed Jan 25, 2006 9:12 am ] |
I fitted some too not long ago and just had to push them into the corners more and try and squeeze it all in. Hopefully it all works out! |
Author: | fuzzy-hair-man [ Wed Jan 25, 2006 9:20 am ] |
I think who ever manufacturers them may allow for some shrinkage as well so when they are first fitted they may seem too big ![]() |
