It is currently Mon Aug 04, 2025 12:19 pm
PostPosted: Tue Jan 24, 2006 4:21 pm
Hi all
Just wondering if anyone has used this gun before and what they thought of it???????.
Ive just seen it on sale for around $445 and thought it would be a good gun for my next mini restoration.
Thanks :P
PostPosted: Tue Jan 24, 2006 7:39 pm
Don't think I know that one specifically, but i'm sure it will be good.
PostPosted: Tue Jan 24, 2006 10:29 pm
thats just the lil bit on the end of the air line right???
pretty expensive stuff.
are all gravity fed ones that price range?
1978 Leyland clubman S.
 Post subject: Gti
PostPosted: Tue Jan 24, 2006 10:41 pm
Devilbiss Gti HVLP gravity guns are the ducks nuts!!!
Not too many guns in this price range that can match it for performance and finish.
$445.00 is CHEAP for one of these set-ups normally they are anywhere between 550-650 depending on sales etc.
If your doing regular work then they are perfect, if you dont want to spend that much then a cheaper brand of gun will get you out of trouble.
I know a painter who has three of these guns and the finish acheivable in the right hands is amazing!!!
PostPosted: Wed Jan 25, 2006 1:35 pm
Nope, i've got a $60 one that does just fine for crap stuff. It actually was ok for semi-decent things too. But its no $450 devilbiss.
PostPosted: Thu Jan 26, 2006 8:55 am
Thanks for all your replys
Just one more question though i get a choice of 2 caps with it #105, & #110 with 1.4mm tip
does anyone know the difference between the two.
Thanks Again :P
PostPosted: Thu Jan 26, 2006 9:15 am
**** oath they are good guns
Devilbiss and iwata and prolly the best guns and we use both of them at work
where are you getting this gun so cheap ????????????
ausmini member #10
(22:42:45) 5 years later..........
PostPosted: Thu Jan 26, 2006 1:20 pm
Its looks as though the #105 air cap is a HVLP one where as the #110 is conventional
PostPosted: Thu Jan 26, 2006 1:46 pm
yer theyre the best guns on the market, it helps the gun not "suck" as your getting towards the bottom, therefor not getting a blotchy finish!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jan 26, 2006 2:56 pm
I just bought it off ebay, the bloke said they were overstocked thats why it was bit cheaper.
:P
Users browsing this forum: Bing [Bot] and 119 guests
