painting radiator
https://www.ausmini.com/forums/viewtopic.php?f=2&t=15445
Author:  =twista= [ Tue Jan 24, 2006 6:37 pm ]
Post subject:  painting radiator
do you think it would be wise to paint the radiator in a heat proof paint? and not just ur normal pressure pack?
Author:  sports850 [ Tue Jan 24, 2006 6:55 pm ]
I've used pressure packs before without any problems , the paint will normally fail because of grease or stuff on the radiator before it fails due to heat . The radiator shouldn't get above 100 degree's (well , maybe a little above under pressure in extreme conditions but you'll have more to worry about then the paint on the radiator at that stage) so it should be alright .
Author:  =twista= [ Tue Jan 24, 2006 6:56 pm ]
thanks bro
Author:  Steve [ Tue Jan 24, 2006 7:05 pm ]
Lightly sand do in enamal primer first then black if its in the car mask up well
steve
Author:  min13k [ Tue Jan 24, 2006 7:08 pm ]
when they put in a new core all they use is cheap black paint
makka
Author:  Mike [ Wed Jan 25, 2006 6:16 am ]
But do not use just the crappy $2 can from bunnings or supercrap unless you want a sticky black swamp with even the slightest suggestion of oil on the radiator. These cheapest paints have absolutely no resistance to oil.
I find the easiest by far is the VHT "quickcoat" use either the gloss or at black. It dries out in minutes, one coat is usualy all that is required, doesnt run unless you fiddle sticks up really badly when using it and is pretty durable.
Author:  britishvita [ Wed Jan 25, 2006 9:22 am ]
This may be a stupid question.... but
If you have the radiator out can you paint the whole thing including the fins etc or will this make it not cool as effectively or block it up???
Author:  Harley [ Wed Jan 25, 2006 9:25 am ]
Just mask it up if not sure.
Author:  =twista= [ Wed Jan 25, 2006 9:54 am ]
it shouldnt block at all, seeings tho the water travels inside the fins.
Am i right? after all theres plenty of other sh*t and gunk around ur fins anyway.
Author:  =twista= [ Wed Jan 25, 2006 9:57 am ]
I find the easiest by far is the VHT "quickcoat" use either the gloss or at black. It dries out in minutes, one coat is usualy all that is required, doesnt run unless you **** up really badly when using it and is pretty durable.
Yeh i used a white knight gloss black, its quick dry, it came up awesome if i do say myself :lol: like u wont be able to see most of the fins when its in, but looks damn good with a lick of paint on the top of the radiator. Looks brand new.
will go well with my fresh motor rebuild
Author:  sports850 [ Wed Jan 25, 2006 9:58 am ]
The clearer the fins are , the more air can flow through them , the more efficient the cooling is . Best to not put too much paint on them but a thin spray to make it look good and the same as the rest of the radiator should be ok . Don't forget too , if you put too much paint on the fins , you're virtually putting a blanket around the core holding the heat in .....
Author:  awdmoke [ Wed Jan 25, 2006 10:01 am ]
The theory being matt black radiates the most heat, and a thin insulating layer of paint is less detrimental to cooling performance than tarnished fins.
Author:  britishvita [ Wed Jan 25, 2006 10:52 am ]
ah thanks for that, didn't want my radiator to be a hot water bottle!! :lol:
