Fuel Guage not working https://www.ausmini.com/forums/viewtopic.php?f=2&t=15476 |
Page 1 of 2 |
Author: | Fat Boy Dave [ Wed Jan 25, 2006 2:50 pm ] |
Post subject: | Fuel Guage not working |
Hi all, the other day my fuel guage stopped working and as yet I've been to lazy to look at it. Any ideas? ![]() Before anyone asks, yes it has fuel, other wise it wouldn't go.... |
Author: | Matt68 [ Wed Jan 25, 2006 3:24 pm ] |
On older models the float is prone to falling off the arm of the sender unit. May be worth checking, but i am not sure of rover set up. Be careful when messing with fuel tank, there is a battery in the boot too remember! If removing the sender unit, make sure there is less fuel in the tank than the hole left by the sender. Cheers Matt |
Author: | Harley [ Wed Jan 25, 2006 3:56 pm ] |
Could be the printed curcuitry on the back of the instrument cluster. ![]() |
Author: | czerial [ Wed Jan 25, 2006 4:32 pm ] |
is always the float when mine goes south |
Author: | poeee [ Wed Jan 25, 2006 4:39 pm ] |
Everything would still be the same as the Aussie Clubman's. The dials are still the same. So considering that, the comon fault with a dodgy fuel guage is usually the sender. ![]() |
Author: | steamer [ Wed Jan 25, 2006 4:45 pm ] |
I've got a dodgy fuel guage it works backwards from 1/2 to full I tryed swaping the connections then it stops altogetther ![]() ![]() |
Author: | Morris 1100 [ Wed Jan 25, 2006 4:55 pm ] |
Just check that you have not knocked a wire off the sender when you have put something in the boot. |
Author: | Fat Boy Dave [ Thu Jan 26, 2006 10:34 am ] |
Wires look to be connected ok on the sender unit. I'll get a multimeter and check the resistance on the sender. Kind of hoping it won't be the circuit board on the dash. Don't really wan't to do it today though due to the heat. |
Author: | marcsvenson [ Thu Jan 26, 2006 10:55 am ] |
mine was a blown fuse is anything else not working |
Author: | Mini Mitch [ Thu Jan 26, 2006 11:42 am ] |
I had a similar problem in mine, then realised i'd run out of fuel. but seriously when i fill up and am hooning to the road the fuel indicator allways starts to read 1/2 full, then less and less, yet when it has the key in the acc position before it is satrted it works all the way. Bizzare. |
Author: | mad-mk1 [ Thu Jan 26, 2006 1:59 pm ] |
mine seems to go to 3/4 and stay there when its full |
Author: | Fat Boy Dave [ Fri Jan 27, 2006 9:17 am ] |
What do you know, now it's working again. ![]() Stupid Lucas electrics..... ![]() |
Author: | Edge [ Fri Feb 17, 2006 5:49 am ] |
Post subject: | damn |
Geez, mine stopped working the day b4 I took it off the road for reconstruction. Now, 4 odd months later, it's still sitting lazy, even after filling. I put a multimeter on the wires at the sender end with ignition on and a strange thing happens. Well, 'least I think it's strange ?? ![]() Is it normal for the voltage to vary, changing about 3 times a second, ranging anywhere from 2.2v to 11.9v and anywhere inbetween? I thought it may have been petrol or something sloshing around affecting this, perhaps with the varying voltage telling the guage what to show, but it does it when I disconnect the wires from the sender and use a earth elsewhere on the body. Any ideas ![]() |
Author: | MrBob [ Fri Feb 17, 2006 5:53 am ] |
If I was a smartarse I'd say something like Maybe your GAUGES would work properly if they were spelled GAUGE not GUAGE !!! But I'm not a smartarse so I wouldn't say anything like that. ![]() |
Author: | Edge [ Fri Feb 17, 2006 6:15 am ] |
Post subject: | ops |
he he, and I work for a newspaper too!! ![]() I'll try that .... "gauge" ... . . . Nup, still doesn't work ![]() |
