It is currently Tue Aug 19, 2025 7:40 pm
 Post subject: handbrake not working
PostPosted: Fri Jan 27, 2006 9:16 am
when i bought spaceboys old clubby the handbrake didnt work!
how can i fix this ?? i doont think the cables are broken
thanx jim
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jan 27, 2006 6:31 pm
resident alien
resident alien
lift it up Image
sorry couldn't help it. are the cables tight?
PostPosted: Fri Jan 27, 2006 6:54 pm
you will have to check it out. Where are the nuts to on the cable at the hand brake. check the quadrets if the are moving and also the mech at the rear brakes
PostPosted: Sat Jan 28, 2006 12:10 am
Yeah How is The Actual handbrake attached to the floor pan cause i ripped mine Off The floor a while back when i found ou the Starter solenoid was Stuffed. Yeah i broke it off the floor.
PostPosted: Sun Jan 29, 2006 4:31 pm
had a look this mornin, cables r intact and not broken, just quite slack.
with the wheel off, i can pull on the cable and lock the rear wheel.
how can i adjust the handbrajke tension??
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Jan 29, 2006 4:42 pm
If you can pull the cable by hand and lock the brakes when jacked up then just tighten the cables a bit at the rear of the handbrake lever , you'll see a nut on a LOOONG threaded rod that's attached to the cable , just tighten the nuts a few turns and try again , a few more turns and try again etc . Best to adjust the brakes a bit at the back wheel as well BEFORE you adjust the cable , just to get things working as well as they can .
Users browsing this forum: No registered users and 158 guests
