It is currently Thu Aug 14, 2025 9:37 am
 Post subject: interior lights
PostPosted: Fri Jan 27, 2006 9:39 am
hey people, my clubby has no gage lights??
is there meant to be?
heres a photo of the dash>
how can i put lights there if theyre not originally there!!
thanx jim
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jan 27, 2006 9:55 am
There should be a high beam at the bottom of the speedo and oil and charge lights on the middle one.
If they aren't there then there are probably places to put globes at the back of the guages and the printed circuit probably has them wires up already.
All the clubby dashes are pretty similar just the tacho sort of got put on the right hand side the front facia type bit may not have the cutouts so tha you can see the warning lights so you might have to try and source this bit from a standard clubby one.
Hope this helps I still can't imagine why it would have no warning lights though :?
One guess might be that they were taken out when the three guages in the middle were added (I am guessing one of these is Amps or volts and another is oil pressure) so the original sensors were probably taken out to fit the sensors for these.
Hope this helps
Roads need more corners
PostPosted: Fri Jan 27, 2006 10:41 am
Try turning the knob i circled..
PostPosted: Fri Jan 27, 2006 11:55 am
I'm assuming you mean there are no lights to see the guages of a night time ? If so , check your park/tail lights as well as they are on the same circuit . There should be an inline fuse holder somewhere under the scuttle panel , behind the air ceaner area-ish in the engine bay . I've found these are likely to be anywhere in the general area but if you start near the air cleaner and work either side you should find it . Sort of tucked up underneath with the windscreen wiper mechanism tube . Find and replace it and see if they work then .
PostPosted: Fri Jan 27, 2006 1:36 pm
the old dimmer trap :)
PostPosted: Fri Jan 27, 2006 10:03 pm
i think i tryed the nob u circled!! ill try again though!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jan 27, 2006 10:09 pm
hey,just turned the nob and boom, we got light!!!
theyre not the brightest things but its better then using my phone light!!!
lol
thanx people
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 293 guests
