metro coils
https://www.ausmini.com/forums/viewtopic.php?f=2&t=15609
Author:  chasg [ Sat Jan 28, 2006 8:10 pm ]
Post subject:  metro coils
Does anyone know the correct coil for a metro 1275 motor with electronic ignition? I am presently using a bosch gt40 coil. Apparently l have read on a few sights that with the metro electronic ignition you need a special coil.
Author:  Morris 1100 [ Sat Jan 28, 2006 8:36 pm ]
The book for my Austin Montego which uses the same type of ignition as the Metro says...
Ignition Coil
Type................................ Ducellier 54041372 or 520029A
Current Consumption- engine idling... 2.3 to 2.7ohms
Primary resistance at 20?C ............ 0.77 to 0.87ohms
Distributor
Type....................... Lucas 59 DM4
Reluctor air gap ...... 0.008 to 0.014" (0.20 to 0.35mm)
Ignition amplifier ..... Lucas AB14 or Ducellier.
I know it does not answer your question but there should be enough info there for someone else to chime in! :lol:
Author:  mini_matt [ Sat Jan 28, 2006 8:52 pm ]
Post subject:  coil
ive got one at work ill check on monday if ya want
Author:  Morris 1100 [ Sat Jan 28, 2006 9:24 pm ]
The coil listed in the Bosch catalogue for the Metro is part number 0 221 119 360 they do not list a GT-40 for them.
Author:  9YaTaH [ Sat Jan 28, 2006 9:28 pm ]
Post subject:  Wheels 2006
Ignition Coil
Distributor
So are we going to see the mighty Austin Montego at Wheels 2006 in March Mike?? :wink:
Author:  Morris 1100 [ Sat Jan 28, 2006 9:57 pm ]
Post subject:  Re: Wheels 2006
I doubt it! 8)
Author:  9YaTaH [ Sat Jan 28, 2006 10:33 pm ]
I doubt it! 8)
Starting to think this Montego is mythical Mike.....how high is the grass under it :P :D
Author:  Morris 1100 [ Sat Jan 28, 2006 10:50 pm ]
It is OK, it is on concrete (unlike the Cooper S) :lol:
Author:  miniimports [ Sun Jan 29, 2006 6:47 pm ]
Post subject:  re coils
think i have some brand new ones(genuine)
pm me if interested
regards josh
Author:  simon k [ Sun Jan 29, 2006 9:21 pm ]
9YaTaH wrote:
I doubt it! 8)
I'll testify that it exists - what a wierd contraption!! :lol:
Author:  simon k [ Sun Jan 29, 2006 9:26 pm ]
I'll give that cooper a good home for you - what I said to you is exactly what I'd do with it, hey, I'd even keep it in mobile storage for you if you wanted ;)
Author:  chasg [ Mon Jan 30, 2006 8:41 pm ]
PM Sent
Author:  Mick [ Tue Jan 31, 2006 9:37 am ]
Didn't they have the resistor switched in for startup?
I think that means you will simple need the GT40R instead of the GT40.
Author:  Morris 1100 [ Tue Jan 31, 2006 4:32 pm ]
Bosch recomends the GT40 range of coils for points only. They list other part numbers for all electronic systems.
Author:  TasTyger [ Fri Dec 01, 2006 7:59 am ]
I know this ressurects an old thread but I need much the same info which didn't seem to be clear when the last repy was posted.
I've got an 4180A 45DM4 Lucas dizzy with the AB14 attached. The coil is Bosch 0221110999.
So the question is which of the GT40/R's can you use in that circumstance. Is it like the pulsar dizzy conversion and you can use the R version or is it same as the Petroix or other electronic kits :?: :?:
TasTyger
