It is currently Wed Jul 23, 2025 1:33 am
 Post subject: Nylon Hydro lines?
PostPosted: Mon Feb 06, 2006 2:32 pm
Anyone ever tried these?
http://www.minispares.com/Product.aspx?pid=33478
Also these copper hydro pipes - wouldn't they be dodgy like copper brake lines?
http://www.minispares.com/Product.aspx?pid=32710
Udo: 1968 Mini - Matic
PostPosted: Mon Feb 06, 2006 2:51 pm
Those nylon tubes look like a great idea!
We use them in heavy industry for compressed air, gland water, and even lube oil - would see no problems using them for this application as they are abrasion & chemical resistant. You could get them made in Oz from a selection of colours too (probably cheaper too) :idea:
PostPosted: Mon Feb 06, 2006 2:58 pm
Yeah I've seen those plastic tubes used for welding gases (argon, CO2 etc) here in welding shops too. Low pressure though, usually around 700KPa.
PostPosted: Tue Feb 07, 2006 1:22 pm
Those lines may simply be copper coated steel for rust protection.
Sounds like a good question to ask them before purchasing though.
