Head Gasket ?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=15761
Author:  Drekkus [ Wed Feb 01, 2006 8:16 pm ]
Post subject:  Head Gasket ?
I was driving home last night when I lost power and started getting a knocking sound.Couldn't get above 50 and barely made it home.
Checked it out today and the knocking sound is coming from the back of the engine and if I pull the plugs on 3 and 4 it makes no difference to the way the car runs.Spark is there and no oil in the radiator water.
Possible blown head gasket ?
Author:  drmini in aust [ Wed Feb 01, 2006 8:35 pm ]
95% probability.. YES :cry:
Put your thumb over each of these 2 plug holes in turn and crank the motor over. No compression on both these cylinders, it's guaranteed 100% a head gasket.
Author:  minicranks [ Wed Feb 01, 2006 8:42 pm ]
could also be a stuck valve or burnt valve, easily checked with the rocker cover off to see if any of the valves are sititng lower on thsoe 2 cylinders.
but yes can be 90% head gasket i would say.
sorry doc had to allow 10% for crappy fuel and burnt seats etc.
Author:  Drekkus [ Thu Feb 02, 2006 8:30 pm ]
Heads off and it is indeed a blown gasket.
http://www.users.bigpond.net.au/drekkus/gasket.html
Author:  matt van'74 [ Thu Feb 02, 2006 8:48 pm ]
atleast it you did it well :shock: it had a meal of that gasket :lol:
Author:  minicranks [ Thu Feb 02, 2006 8:52 pm ]
there is a lot of black around the gasket.
I would not use a copper gasket in the new one i would go for the ACL black gasket for the future after the head has been checked etc.
well done for finding it.
