It is currently Sat Jul 19, 2025 7:18 pm
PostPosted: Wed Feb 01, 2006 10:20 pm
look what i got done... :D
Must give whopping great chunks of appreciation to Steve and the lads at Brickworx for damn fine work. Especially for working in rediculous heat and torrential downpours not to mention all the extra bits that seemed to somehow fall onto my car ;)
now i'm in the same boat as william, needing a set of those Mk1 ;) cooper flares.. :)
..and some sand dunes to test my new 4x4 ride height :)
PostPosted: Wed Feb 01, 2006 11:03 pm
:lol: Full offroader style.
PostPosted: Thu Feb 02, 2006 8:30 am
nice work, did u blingem up?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Feb 02, 2006 8:32 am
cush is the king of bling
ausmini member #10
(22:42:45) 5 years later..........
PostPosted: Thu Feb 02, 2006 9:06 am
they're currently quite un blinged, but considering they're under steelies, i don't think it really matters...
*reaches for the alfoil*
PostPosted: Thu Feb 02, 2006 11:10 am
You could ditch the spark plug leads and simply use the alfoil. Might save some weight and it's a great conductor.
You might have to wrap some of the alfoil with electrical tape near the dizzy to stop the spark from jumping over.
PostPosted: Thu Feb 02, 2006 12:01 pm
the car actually ran fine with the foil on there...
:P
PostPosted: Thu Feb 02, 2006 11:08 pm
Here's some more piccies showing my new track/offset with me inno flares resting on.
PostPosted: Fri Feb 03, 2006 7:39 am
I would BLING the Inno flares by using S/S self tappers from yer local boat shop. :D
If you don't, the rust lines on the flares in a month or two from the POS steel screws looks decidely Un-Bling... :cry:
PostPosted: Fri Feb 03, 2006 7:47 am
i'm planning on hidden screwing them on through the lip, so i can put the MK I Cooper s Flares on later.
but i shall still use the stainless steel screws... cheers...
