It is currently Thu Jul 17, 2025 2:17 am
PostPosted: Fri Feb 03, 2006 2:41 pm
its time to bite the bullet. my poor 1100 needs either a complete rebuild or complete new 1100? what would be cheaper .
wuld it be reasonable to then rebore the 1100 ????
PostPosted: Fri Feb 03, 2006 3:34 pm
just rebuild it mate! pleanty of good 1100;s on this site! just ask for help on spec dtc
from people!
PostPosted: Fri Feb 03, 2006 3:52 pm
Either way its a rebuilt 1100, you can't buy a new one so its either rebuild the one you have or get a rebuilt one supplied
:D
PostPosted: Fri Feb 03, 2006 4:01 pm
and what price is a rebuild????? im in need of a rebuild.....the engine is pushing out a lot of smoke....... so a for a basic rebuild should expect it to cost around 600????
PostPosted: Fri Feb 03, 2006 4:05 pm
hmmm i would be sayin a little more than that,
I would say about 1500 for a short motor (no head or gearbox or ancillaries (sp))
around that figure anyways. thats new rings,pistons, crank grind etc. give your
local mini places a call. it may be cheaper to just buy the short motorand put your
head and gearbox on there. :wink:
PostPosted: Fri Feb 03, 2006 4:07 pm
ouch that hurts........lot of money for me........what about just new rings, valves , and gaskets?????
PostPosted: Fri Feb 03, 2006 4:09 pm
if you put new rings in then you will have to at least hone the block to make
it worth while. maybe just try getting the head reco first. it could just
be the valves, it will be cheaper than new rings :wink:
PostPosted: Fri Feb 03, 2006 4:15 pm
Harvey
It is usually the case that if it needs rings it needs a rebore and new pistons and the crank will need at least a polish and new bearings just for a start, there are no short cuts in rebuilding engines not in the long run any way. probably looking at $2-2500 for a new recon engine supplied and fitted and more if you do the gearbox which you really should with a mini
Jon
yer true...... the problem is if i get that done then it ends up being the rings im stuffed....lol
PostPosted: Fri Feb 03, 2006 4:16 pm
what sort of price are reond. 1100s?????
PostPosted: Fri Feb 03, 2006 4:17 pm
hmmm , hate to say the obviopus mate, but i think you just need to
bit the bullet and get the motor out for a full rebuild, I got a 998 reco short
motor for 1500 a few months ago. I think that is ver reasonable
PostPosted: Fri Feb 03, 2006 4:21 pm
yer i think thats recond. the engine i got is the way.....
will it fail a blue slip if there is smoke comin out......???? like not heaps but noticeable
thanks heaps for the help.
