It is currently Sat Jul 19, 2025 1:06 pm
 Post subject: Mini Firewall Question
PostPosted: Thu Feb 02, 2006 11:35 am
What material can be used to cover the Mini firewall stop the fumes from entering the car. Also is there a template somewhere to make it?
Smell like petrol after every drive. lol
PostPosted: Thu Feb 02, 2006 11:43 am
If it smells like petrol check and double check all your rubber hoses going into the carby.
I bought some sound deadening stuff that seems to have worked a treat from clark rubber a few weeks ago, wasn't much a meter and was pretty wide so I only needed a meter and a half or so and I still had heaps left over. As for fitting I just measured the width of the firewall and then cut it as I went along height wise. Putting it in as three seperate parts made the job a lot easier too.
Shard
PostPosted: Thu Feb 02, 2006 11:55 am
G'Day Katzzmandu,
If you have petrol smell then you need something that wont burn :roll: however if you want to keep your car and have SU carburettor(s) look for wet / dirty marks on the float bowl cover. The gasket can leak and there is an overflow hole where the fuel line connects. (could be hidden under a small aluminium cover). This usually means your float is set too high or your float valve is cactus. Cheap to replace esp. seeing your exhaust pipes are just underneath.
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Thu Feb 02, 2006 11:59 am
make sure your grommets are all in their holes... ie.. where the accell and choke cables pass through..
PostPosted: Thu Feb 02, 2006 12:16 pm
If you have a petrol smell, i would be looking into the souce of the problem rather than trying to cover it up..
PostPosted: Thu Feb 02, 2006 1:00 pm
meh.. if you have a petrol smell then you're driving a real mini :)
PostPosted: Thu Feb 02, 2006 1:08 pm
I could smell fuel occasionly when driving my car. Turned out to be gasses coming through the hole in the gear change boot/ gaiter thing whatever it is.
PostPosted: Thu Feb 02, 2006 2:23 pm
:lol: :lol:
PostPosted: Thu Feb 02, 2006 3:27 pm
You can get the black vinyl backed sound deadening from most upholsterers. Works quite well, but isn't flame proof.
I always get the strong smell of petrol if the overflow tube on top of the fuel tank has been disconnected form it's rubber pipe. Fuel goes into the boot and wafts really strongly through to the cabin while driving.
Might be worth a look.
Mick
PostPosted: Fri Feb 03, 2006 7:47 am
yer......like........fix the problem, don't cover it up - or it may fix you!!!!
Rod Image
PostPosted: Fri Feb 03, 2006 8:30 am
after you have checked the baulk head and carb area for fuel leaks then i would head to the boot and make sure the overflow pipe is connected to your tank at the top and is vented correctly thru the floor.
If the pipe is split brake or nopt connected you will get an overwhelming fuel smell in th car causing hullecenations making you think your car is a ferrari and can out race any one form the traffic lights. damn it must be happening to me all the time then cos i can do that all the time.haha.
check the fuel tank breather pipe to see if its connceted.
www.minicranks.com add me to your watch list and come back again soon, under construction.
Users browsing this forum: Bing [Bot] and 66 guests
