It is currently Sat Jul 19, 2025 3:24 am
 Post subject: boost though a dellorto?
PostPosted: Wed May 26, 2004 6:25 pm
is it possible to boost a dellorto carburettor (using blow through)? thanx ben
lookin for another clubby
PostPosted: Wed May 26, 2004 7:14 pm
Just set it up as a suck through, man.
PostPosted: Wed May 26, 2004 7:32 pm
Yes it is, as in Vizard's book, but carb was special for a Lotus.
Jukka Harkola (MM site) did it on a Mini with turbo, had lots of grief to get it right.
Suck-thru is commonest for supercharging, but not great for turbo where the turbine runs a zillion rpm.. :wink:
PostPosted: Wed May 26, 2004 7:35 pm
yeh, jukka built a v8mini (east west) aswell it fitted in a clubman enginebay without mods :D
PostPosted: Wed May 26, 2004 7:37 pm
Wasn't Jukka- I think his bro. Look on that V8 site, there's a link to Jukka's turbo Min stuff.
PostPosted: Thu May 27, 2004 5:02 pm
oh yeh, my bad, i remembe his name though
they had a rover v8 powered morris minor aswell :)
PostPosted: Tue Aug 17, 2004 2:18 pm
found this on google groups (USENET) while reading up on dellortos:
A friend has been working on a turbo conversion for his mini, but
having already had a straighforward Metro Turbo conversion, he decided
on something a little different:
Dellorto 45 DHLA, (as used on the Lotus Turbo Esprit)
Intercooler
Dump valve
Front mounted (Mk2 Metro) radiator
Straight cut box and drop gears.
Maniflow exhaust
Safety devices roll cage
7x13" Superlights
Polycarbonate windows
Fibeglass boot and bonnet
Twin tanks
Metro four pot calipers and vented disks
as well as the usual HiLo's, adjustable shocks etc
Anyway, he finaly got the engine running after a couple of weeks of
nightmares. The enigne ran first time but a load tapping noise was
comming from the area of the timing case. After removing the timing
cover nothing was found, but the noise was still there, and not
sounding healthy. He decided to remove the engine and strip it,
mainly for his own peace of mind, but found nothing, and the noise was
still present after reassembly. Eventualy, it was found to be nothing
more serious than the crank pulley was touching a high spot on the
timing cover!
The next plan is to sort out a distributorless ignition, as the
raditor doesn't leave a lot of space! He's aquired a distributorless
coil from a F*rd and we have come up with a way to modify the existing
distributor to just provide timming for the sparks, but no spark
distribution.(and therefore no distributor cap/ht leads)
Anyway, he's got a digital camera, and he's not afraid to use it, so
he's put hnudreds of pic's on his web site. If you are interested
take a look at
http://www.users.globalnet.co.uk/~mlarj ... stuff.html
picture link still works, love the air box!
PostPosted: Tue Aug 17, 2004 3:18 pm
The biggest problem you have is that you have to pressurise the float chambers so the fuel flows in the right direction on boost, and seal a whole heap of fiddly little bits to make sure that the boost pressure does not force stuff in the wrong direction. Plus you have to fiddle a lot to get your mixtures right because it is not a common thing to do. The big advantage with the blow through is you can use an intercooler before the carby.
Ever wonder why turbocharching never really took off untill EFI was sorted?
PostPosted: Tue Aug 17, 2004 7:06 pm
Eurocarb can help you- they stock all the bits for the Esprit turbo's special 45 Dellorto carb.
www.dellorto.co.uk
PostPosted: Tue Aug 17, 2004 7:26 pm
Check out:
http://www.geocities.com/jharkola/1380turbo.html
He did a Dell'orto turbo, but was running a DHLA 45M carb already modified for a turbo. It is my understanding though that you can modify a normal Dell'orto to use as a blow through.
As for using it on a suck through, it seems to me a bit pointless running a twin choke carb on a suck through turbo, but maybe it's just me!
Anto
PostPosted: Wed Aug 18, 2004 5:33 pm
Janspeed's blow through turbo setup used a dellorto....its in Vizards book somewhere.
[Maverick] 1971 Mini K
PostPosted: Thu Aug 19, 2004 1:53 pm
There was a two barrel downdraught Weber specially made for blow-through turbos.
One sold on e-Bay a few months ago - 34DMTT I think?
You can get a manifold to fit this carb onto a Mini, as the popular 28/36DCD and 32/36DGV carbs use the same bolt spacing. 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: No registered users and 119 guests
