It is currently Sun Jul 27, 2025 8:27 pm
PostPosted: Sun Feb 12, 2006 4:04 pm
[b]PROBLEM FIXED[/b]
i am in the process of replacing my drum set up with better a drum set up and i have got the passengers side all off but the rose joint on the drivers side doesnt want to split.
i have been using a scissor style splitter but no luck. is there are another way to crack these joints :?
thanks heaps[/b]
PostPosted: Sun Feb 12, 2006 4:15 pm
Rose joint? I think you mean ball joint. (rose joints are different)
The other way to pop the joint is to hit the side with a hammer or better still, two hammers, one each side.
One big hit! Not a lot of little hits.
PostPosted: Sun Feb 12, 2006 4:51 pm
Put the front up on stands under the sub frame, use your jack under the drum to lift up the top arm from the body and put a spanner in the gap and lower the jack. Undo the top nut till only on by a couple of threads. then hit the ball joint with a hammer. and pop she'll go. If your not doing it today PM me and I'll take photos for you for tommorrow arvo.
steve
PostPosted: Sun Feb 12, 2006 5:45 pm
i have undone the top and bottom ball joints and the centre nut.
this is the one i am having trouble with it :oops:
(circled in red)
if anyone knows what this is called let me know
thanks for the offer steve but i am kind of past the beginning now :cry:
thanks for the help :)
PostPosted: Sun Feb 12, 2006 5:55 pm
i just had another go with the German Screwdriver and it finally undid!
thanks for the help :D
PostPosted: Sun Feb 12, 2006 6:01 pm
Tie-rod end.
Glad I could help!
PostPosted: Sun Feb 12, 2006 6:23 pm
matt van'74 wrote:
German Screwdriver
German - never heard that before, I like it.
PostPosted: Sun Feb 12, 2006 6:25 pm
it is another name for a hammer :!: my said it this morning so i stole it
Cylinders are dead MAtt :?
PostPosted: Sun Feb 12, 2006 6:27 pm
yeah they are the throw away drums :wink: nice recond drums waiting to be put on :D :twisted:
PostPosted: Sun Feb 12, 2006 6:37 pm
Matt I'm so jelous
steve
That bottom shoe will be full of oil also so i'd toss them also.
WHile your doing also this I would also check for the wheel bearings, bit late for this side as the wheel is off
PostPosted: Sun Feb 12, 2006 7:29 pm
Yeah I think he's replacing everything, completely new (recoed) drums..
PostPosted: Sun Feb 12, 2006 8:10 pm
yeah i am replacing the whole lot with a set WhoDat had that he ran on his van for a little while before he got discs.
Steve if any one is jealous its me! i want bruiser :!: but then again everyone with an interest in minis wants bruiser :lol:
thanks for help everyone :D
Users browsing this forum: diecast and 97 guests
