cutting Suspension trumpets https://www.ausmini.com/forums/viewtopic.php?f=2&t=15913 |
Author: | czerial [ Mon Feb 06, 2006 9:08 am ] |
Post subject: | cutting Suspension trumpets |
So is this a legitamet (sp) was to lower a dry mini? I would like to do this on my 74 Clubby (obviously dry). I have heared that it is not good to do this, but if using the correct measurements from Vizard, is there anything wrong with doing this? I would fit Hi-Lo's but i dont have the money,,, and this car has got to drop some ![]() |
Author: | Harley [ Mon Feb 06, 2006 9:14 am ] |
Have you got a lathe? You'd only be removing about 5mm tops I'd imagine. Much more and you'll need spacers again. |
Author: | sports850 [ Mon Feb 06, 2006 9:37 am ] |
I've found it to be safe , just make sure you double check the measurments and ratio's as they are different for the front and rear , just can't remember off hand . One was 1:5 (front?) I think and the other 1:3 ? In other words for evey inch you cut off that's how far the suspension will drop , a little cut will make a big difference to height so make sure you get the measurments formo a reputable source , if you're using Vizards info then you should be right . |
Author: | czerial [ Mon Feb 06, 2006 9:49 am ] |
thanks mate! Its just once i was contemplating doing this and someone said that it is not a good way as it stuffs up the suspension and that Hi Los were much better, But the way i see it. it is basiucally the same principal. you either have a short metal bar (hi lo) or a short trumpet.. no real difference? |
Author: | sports850 [ Mon Feb 06, 2006 9:59 am ] |
And remember , you'r only cutting 1/4" or so off anyway , not actually weakening it . All I'd suggest is to choose a cooler method of cutting it off , with a hacksaw or on a lathe as opposed to a grinder with a cutoff wheel . |
Author: | czerial [ Mon Feb 06, 2006 10:03 am ] |
excellent thanks mate. will take them down to the local machine shop and get them to stick it on a lathe! |
Author: | drmini in aust [ Mon Feb 06, 2006 10:09 am ] |
sports850 wrote: I've found it to be safe , just make sure you double check the measurments and ratio's as they are different for the front and rear , just can't remember off hand . One was 1:5 (front?) I think and the other 1:3 ? In other words for evey inch you cut off that's how far the suspension will drop , a little cut will make a big difference to height so make sure you get the measurments formo a reputable source , if you're using Vizards info then you should be right .
It's the other way around- fronts are 1:3 and rears 1:5. ![]() |
Author: | czerial [ Mon Feb 06, 2006 10:12 am ] |
thanks. So is it worth cutting the front also? im not replacing the cones. so they may be flat from the engine. how much does it lower the car. I dont want it to be riding on its bump stops |
Author: | drmini in aust [ Mon Feb 06, 2006 10:14 am ] |
czerial wrote: thanks.
So is it worth cutting the front also? im not replacing the cones. so they may be flat from the engine. how much does it lower the car. I dont want it to be riding on its bump stops 1/4" off fronts will lower 3/4" approx. cut them straight... |
Author: | sports850 [ Mon Feb 06, 2006 10:15 am ] |
drmini in aust wrote: sports850 wrote: I've found it to be safe , just make sure you double check the measurments and ratio's as they are different for the front and rear , just can't remember off hand . One was 1:5 (front?) I think and the other 1:3 ? In other words for evey inch you cut off that's how far the suspension will drop , a little cut will make a big difference to height so make sure you get the measurments formo a reputable source , if you're using Vizards info then you should be right . It's the other way around- fronts are 1:3 and rears 1:5. ![]() Thank's Kev , couldn't remember off hand and couldn't be bothered searching since czerial mentioned having the books . I've seen what happens when somebody decided to lower a mini all round by two inches , removed all 4 trumpets while the car was on stands and cut two inches of each trumpet before refitting them all .... ![]() ![]() |
Author: | czerial [ Mon Feb 06, 2006 10:19 am ] |
thanks guys ![]() |
Author: | fuzzy-hair-man [ Mon Feb 06, 2006 10:28 am ] |
Just check that there isn't some spacer washers on your knuckle joints already you might not have to cut anything off ![]() There was also a bit about lowering minis by cutting the trumpets on minimania's website here we go this looks like it: http://www.minimania.com/web/SCatagory/SUSPENSION/DisplayType/Calver%27s%20Corner/DisplayID/1231/ArticleV.cfm |
Author: | czerial [ Mon Feb 06, 2006 10:33 am ] |
thanks mate ![]() |
